boost fooler ?
Old Apr 17, 2013 | 08:27 AM
mikec91's Avatar
mikec91
boost fooler ?
Anybody know about them
Old Apr 17, 2013 | 09:43 AM
Hussler's Avatar
Hussler
Depends what you are referring to. There is a boost fooler that will limit the amount of boost to keep the truck from De-fueling. If you are referring to fooling the PCM into thinking there is more boost than normal then it is difficult to do. The reason is our MAP sensors are frequency based and not analog based.
Old Apr 18, 2013 | 12:31 AM
oldbird1965's Avatar
oldbird1965
Jim, Jonathan at No Limit Tuning told me because I put the s366 turbo on to use a boost fooler so the map sensor doesn't get ruined seeing to much boost. I have a dieselsite boost fooler and always thought that its purpose was to limit the amount of boost the map saw so the PCM wouldn't defuel. I took it off, IDK
Old Apr 18, 2013 | 07:59 AM
Jennifer at DS's Avatar
Jennifer at DS
Our Boost Relief Valve fools the map sensor into seeing less boost than the truck is actually making. It does this with a bleed off valve. It is a mechanical fix as opposed to electronic. When the map sensor detects 24 lbs of boost for an extended period of time, the truck will throw a code and will defuel.
Tuners now have the ability to turn up the boost limit value on the PCM. Our Boost Relief Valve is a $50 alternative for those who don't have it in their tuning.
Old Apr 18, 2013 | 08:10 AM
mikec91's Avatar
mikec91
The reason I ask is I only see 16 psi max did know if it
would help build boost
Old Apr 18, 2013 | 09:25 AM
oldbird1965
It will not help build boost.
Old Apr 18, 2013 | 12:55 PM
tjc transport's Avatar
tjc transport
i ain't rite
a boost fooler will not raise boost levels on a stock truck.
as the others have said, it is a pressure regulator to trick the map sensor into thinking the truck is making less boost than it actually is after adding a tuner.
Old Apr 18, 2013 | 01:07 PM
mikec91's Avatar
mikec91
I have a chip ,down pipe ,t500 hpop ,inter cooler , and I have check for ex leak and there are none
Old Apr 18, 2013 | 01:28 PM
DarkStarMedia's Avatar
DarkStarMedia
Where are you measuring boost? Hot side of the intercooler or cold side?
Richard
Old Apr 19, 2013 | 06:55 AM
mikec91's Avatar
mikec91
The hot side
Old Apr 19, 2013 | 09:52 AM
cowmilker08's Avatar
cowmilker08
16-psi seems pretty low. I can pull 20 psi easy and all I have done is opened up the air stream. If I keep my foot in it long enough in 3rd gear I hit 23-psi.
Have you checked for leaks on the intake side?
Old Apr 19, 2013 | 09:55 AM
oldbird1965
Yeah but isn't that with the 1.0 housing?
Old Apr 19, 2013 | 09:58 AM
cowmilker08
No that was the numbers I was getting with the 1.15 housing. I haven't had the gauge in since I did the 1.0.
Old Apr 19, 2013 | 10:14 AM
mikec91's Avatar
mikec91
Thanks I will check . Will a bad map sensor cause it if
So how would you check it
Old Apr 19, 2013 | 11:51 AM
stainlessstroker95's Avatar
stainlessstroker95
Have you checked for leaks? Maybe on the up pipes.
