6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
EGR Delete
Old Apr 16, 2013 | 01:08 PM
sglass57's Avatar
sglass57
EGR Delete
Is it worth it to delete the EGR I have a spartan tuner and DPF delete so should I delete the EGR i have all the parts to just it looks like a bit**. any advice
Old Apr 16, 2013 | 04:33 PM
senix's Avatar
senix
It won't increase your mpgs...if that is what you are after.
Old Apr 18, 2013 | 01:33 PM
sglass57's Avatar
sglass57
Ok thank you
Old Apr 18, 2013 | 07:26 PM
bubbasz1's Avatar
bubbasz1
To delete the EGR would guarantee that you would never bend a rod from a egr cooler leak, not that bad coolers are a big problem with the 6.4, but it does happen. If you have the parts I would do it, plus it will declutter the engine compartment a tad.
Old Apr 20, 2013 | 09:57 AM
Delta2142's Avatar
Delta2142
I was told by a mechanic if the EGR's are gone I risk a high pressure event that will blow my head gaskets.
Old Apr 20, 2013 | 10:09 AM
senix's Avatar
senix
Boost. Have to watch it since no waste gate. Egr acts as the waste gate
Old Apr 20, 2013 | 10:17 AM
GHeTTo JOe's Avatar
GHeTTo JOe
will having the boost defuel limit set act the same as a waste gate to an extent? i know i can still go over the set limit slightly but not hardly.
Old Apr 20, 2013 | 10:38 AM
bubbasz1's Avatar
bubbasz1
Lots of people run egr delete without blowing head gaskets, you would really have to running it hard to do damage, many posts on egr deletes, time for more reading to make a intelligent decision.
Old Apr 20, 2013 | 10:51 AM
senix's Avatar
senix
Yes you can your defuels or boost alarms. Lots do not have a problem
Old Apr 20, 2013 | 06:16 PM
spoolen&smoken's Avatar
spoolen&smoken
I have a thread on this. I called spartan wondering the same thing about wategates. They feel confident that if you're not adding more than 500hp to your truck it will be ok. I'm taking my egr off for the simple reason its a junk set-up.
Old Apr 21, 2013 | 08:17 AM
Delta2142's Avatar
Delta2142
Will do. Finally decided to delete the DPF/Cat , will happen Tuesday.
Old Apr 21, 2013 | 10:20 AM
bubbasz1's Avatar
bubbasz1
Report back on what you think.
Old May 1, 2013 | 01:54 PM
Delta2142's Avatar
Delta2142
It's like getting a new truck. Put your foot in to it she jumps and sounds like Truck again.
Old May 1, 2013 | 07:33 PM
bubbasz1's Avatar
bubbasz1
Isn't that a happy thing.
Doc Juju
Apr 28, 2022 09:18 AM
diamondrcattle
Jan 22, 2014 01:35 PM
bebeard
Oct 12, 2012 09:26 PM
parkland
37
Oct 28, 2011 02:09 PM
