Engine ideas?
Old Apr 16, 2013 | 08:55 AM
mdlave's Avatar
mdlave
Engine ideas?
1978 F150 4x4 w/ C6 with a 460 from a 1973 Lincoln. Last time it was run was a couple weeks ago. Had old gas in it at that time, which I drained and replaced.
Teeth from the starter pinion gear broke. Checked out teeth on the flexplate. Flexplate definitely isn't new but all the teeth seem okay. Replaced the starter, and it turns the engine over, but not as evenly as I think it should. All the electrical connections and grounds are good. I don't want to spend too much time cranking it until I'm sure that there aren't other mechanical issues that need attention.
I was told to check out the pushrods. I pulled them, and all are straight, but several have some scorching/burn residue on them.
Should these be replaced? What should I do to make sure they are properly seated and lubricated when they are replaced? What should I look for on the rocker?
What else should I check or replace while I'm there?
Engine oil level is good, it hasn't been run dry. I'm not opposed to removing the intake manifold to get at other things.
Thanks, this forum has been extremely helpful with this project.
Old Apr 16, 2013 | 06:42 PM
billgrant's Avatar
billgrant
not sure what you mean by evenly. pull the plugs and take a compression ck. see if
all the cyl. are about the same. 110-140 lbs leave pushrods alone. if straight and oil
hole is clean their ok
Old Apr 16, 2013 | 08:32 PM
bamaf150's Avatar
bamaf150
So whats the matter with it?
Old Apr 16, 2013 | 09:10 PM
mdlave's Avatar
mdlave
Hopefully nothing. My knowledge of the engine's history doesn't go very far back, so I just want to make sure that if some other problem contributed to the starter pinion's failure, I've addressed it so it won't happen again.
Red buck
Dec 28, 2017 12:36 PM
3percenter77
21
Jul 13, 2017 06:05 PM
BrittsNFords
15
Apr 13, 2016 10:47 AM
mdlave
22
Apr 15, 2013 07:42 PM
