Starter locking engine up?
Old Feb 28, 2016 | 09:28 PM
BrittsNFords's Avatar
BrittsNFords
When starting the starter would occasionally grind so I decided to get a new starter. After replacing it started a few times and then locked up. Like it wasn't grinding but wasn't turning over. Tried turning the engine over by hand to move the flywheel but it was locked up. The starter gear wasn't retracting. I guess I need to do the fly wheel now. I thought I would check here for any other things to test before pulling the engine. I re-seated the starter a few times with the same results.
Is there anything else to test here before pulling the engine?
Old Feb 28, 2016 | 09:33 PM
HIO Silver's Avatar
HIO Silver
Check the flywheel for run out. It could be loose and wobbling. Hence the binding issue. That means removing the inspection plate and setting up a dial indicator and observing while rotating the engine by hand. A good time to visually inspect it at the same time.
Safety first! Disconnect the negative battery cable so there is no possibility whatsoever of errantly arcing the starter.
Old Feb 28, 2016 | 09:52 PM
BrittsNFords
Thanks HIO. The teeth are looking pretty chewed up. I don't own a dial indicator so I cant get a good measurement in that sense at the moment. It doesn't feel loose but my friend said he thought he saw some warping while turning it over. I'll see if I can borrow one tomorrow.
Old Feb 28, 2016 | 10:07 PM
HIO Silver's Avatar
HIO Silver
If ya don't have a dial indicator, anything that can provide a constant measurement may work. For example, a turn buckle and two lengths of threaded rod. The actual measurement is unimportant. Check it every 90°.
Old Feb 29, 2016 | 09:13 PM
kenny nunez's Avatar
kenny nunez
Starter locking
Quite often rebuilt starters come with rebuilt drives. The leading edge of the gear has been trimmed back which can cause this to happen, especially if the flywheel is already beat up. Go to the auto store and buy a NEW starter drive. Rebuilt ones will have "rebuilt" stamped on them. Compare the drives and you will see the difference between the end of the gear and the end where it meets with the housing. This may help if the flywheel is not completely trashed.
Old Mar 4, 2016 | 02:29 PM
BrittsNFords
Thanks for the replies. On further inspection the fly wheel looks really chewed up. Some places are missing teeth completely. I guess I'm going to pull the engine. Just need to save up some money for parts.
I'm thinking while the engines out I'll paint the engine compartment black and try and replace all the leaky gaskets from not running the thing for a few years. The engine feels under powered and there's a big lag between putting your foot down and moving so I'll try to figure that out too. It seems okay at lower RPMs but has a hell of a time speeding up to pass people on the interstate.
Anything I should add to my list to check while the engines out?
Old Mar 4, 2016 | 02:37 PM
qman's Avatar
qman
The teeth on my flywheel looked like the following pic. It would start the engine but it would destroy a starter gear after about 2000 miles.
Old Mar 4, 2016 | 04:23 PM
ultraranger's Avatar
ultraranger
I didn't see any mention of what transmission you have. If it's an automatic, you would have a flexplate. If you have a manual transmission, you would have a flywheel.
I didn't see any mention of the engine size either. I'm not certain on the FE engines but in the case of a Ford small-block (like a 302), there are two different starter Bendix lengths, depending on the type of transmission you have. The snout length of the Bendix is shorter on a manual transmission starter for a Ford small-block than the Bendix snout length for an automatic transmission.
Aside from the ring gear being chewed up on your flexplate/flywheel, the Bendix drive gear on the starter can get hung up on a perfectly good ring gear (stay engaged and not retract) if the wrong starter is used on a small-block --again, not sure if the Bendix drive snout on a starter for an FE is configured the same way (?).
Old Mar 4, 2016 | 10:14 PM
BrittsNFords
My bad its a 360 FE with automatic C6. Haha gman that looks about right. If yours still started maybe the flex plate has some run out. Would I have to pull the engine to get the crank or do you mean the bolts you can see through the dust shield?
Old Mar 4, 2016 | 10:50 PM
ultraranger
It would be easier to slide the transmission back, or take it out, than it would be to pull the engine to get to the flexplate.
Old Mar 4, 2016 | 11:33 PM
orich's Avatar
orich
I'd do a compression test before pulling it a part. This may tell to why low on power.
Also common problem some guys never do much of a tune-up and never check if the dizzy vacuum advance is in good working order.
An ez way to check it remove vac hose from carb an sucking on it. You must remove dizzy cap tho so you can watch the vac. can move. If you keep getting air while sucking on the hose it's bad and needs replacing.
Orich
Old Mar 7, 2016 | 11:11 PM
JEFFFAFA's Avatar
JEFFFAFA
Orich
2X.
Also, if you do pull the engine rather than the tranny, I would change all gaskets, seals, timing chain for a good Cloyes brand set, and the freeze plugs.
Old Mar 8, 2016 | 09:37 AM
qman's Avatar
qman
Like I said, my flex plate looked like that pic. Luckily for me (if you wanna call it luck) the C6 leaked oil to the tune of a qt a week. So I was pulling the C6 anyway to seal it. While there I put in a new flex plate. Now the engine really spins when starting. It's like an entirely different car.
Old Apr 10, 2016 | 10:14 PM
BrittsNFords
Thanks for all the advice fellas. I borrowed a transmission jack from a neighbor and backed the transmission up enough to get flex plate replaced and now it starts like a dream. The hardest part was maneuvering the transmission just right to get that front cross member out of the way. Had some trouble getting the nuts off the torque converter. Learned the hard way that some things should be loosened with a box end and not an air wrench
Thanks again this was my biggest maintenance project yet
Old Apr 13, 2016 | 12:18 AM
JEFFFAFA's Avatar
JEFFFAFA
Glad to hear everything is back together runnin' like Jack the Bear after Sue the Bear. Those torque converter nuts are locking nuts only meant to be used once. If you re-used them I hope you put some thread locker on the studs so the nuts won't back off. AKA like GM's do. Both my brother's cars did. 77 vette and other brother's 89 Camaro. Both had never been touched from the factory.
