Warning on using penetrating oils, lubricants and rust busters.
Old Apr 16, 2013 | 07:37 AM
old broke prospector's Avatar
Hey body guys and tinman .... chime in on this please.
I recently got a lecture from a body shop guy about using lubricants, especially anything with silicone.
Silicone is suppose to be the touch of death to a paint job. His opinion is to bust the nut or grind off the bolt/nut before using lubricants or rust busters.
I was told in no uncertain terms not to bring any silicone based products into his shop as they will cause "finger printing and wrinkled paint that will peel off with a fingernail.".
Learning something new every hour...
Old Apr 16, 2013 | 08:42 AM
tinman52's Avatar
tinman52
Welder User
Yeah, silicon and wax are my mortal enemies..........especially Armour All type cleaners. Also when doing bodywork, wash your hands often and for sure after you eat lunch as the oils from your hands can cause problems as well. I wear rubber gloves for most sanding....
Old Apr 16, 2013 | 09:03 AM
schoo's Avatar
schoo
Used ppg bug and tar remover before sanding after sanding before painting
Stuff smells bad but seams to work
Old Apr 16, 2013 | 09:57 AM
daveengelson's Avatar
daveengelson
Was not aware, I tend to used the Kroil silicone; although just changed to regular Kroil penetrating oil at the suggestion of the auto parts person, and apply to nuts and bolts before starting project, let it set overnight and found it helpful in removing rusted and frozen hardware. Again, thanks for the heads-up.
Old Apr 16, 2013 | 12:27 PM
Jetcopterpilot's Avatar
Jetcopterpilot
Wash those oils off with "No-rinse TSP liquid", found at most home improvement stores...... do not get it on your skin, as it will suck the oils right out of your skin and will burn you... then you can do your wipe down with standard prep cleaners, or lacquer thinner as you normally would... The No-rinse TSP will etch your paint to a degree, it is very harsh on paints, but for prepping your paint surface it is ideal.... it promotes good adhesion.
Old Apr 16, 2013 | 09:53 PM
C G B's Avatar
C G B
Silicone is definitely bad when it has anything to do with painting. Fish eyes are the big one if I remember right. Silicon spray is near worthless except for very limited plastic lubrication applications.
However, 3M silicon grease for some applications simply cant be beat. I use it all the time when doing brake jobs, lubing window tracks and regulators, anywhere I need something that will hold up to the weather over time better than regular grease might.
headgoatroper
1947 and Older Ford Trucks
Mar 23, 2010 09:25 AM
Red77F100
Paint & Bodywork
Aug 19, 2006 05:03 PM
Cornbread
Paint & Bodywork
Mar 19, 2005 04:23 AM
gktbay
Paint & Bodywork
Apr 30, 2004 10:11 AM
rompin78
Paint & Bodywork
May 2, 2003 04:55 PM
