Body prep
Going back to the resto project I am working on. 78 F-150 4x4 Buddy and I were talking about body work on my cab and pretty much the fenders and box.
My original thoughts on getting the body done, was to have it sandblasted, and undercoated with line-x. But after talking to him, for someone like me, there might be a cheaper way, with same amount of satisfaction. I'm not too picky!
I don't plan on showing my truck so it’s not like I need a $3k paint job, plus I do plan on using it when I go camping, 4-wheeling, and an alternative as a daily driver (just depends what the gas prices are like!) Plus it will be garaged when I'm not driving it, so having it repainted every 3-4 years doesn't bother me.
So the question is, sanding. What grit of sandpaper? It’s been painted once before, looks more like a primer then paint, its kind of rough. And it wasn't striped. So I have this nice aqua green, where they didn't paint over it with white.
Another question how much should I take it off, not down to bare metal I would think. Buddy mentioned that if sandblasted it, then I would have to do the whole etching primer and wet sanding, and all that. May not have a choice in the surface rusted areas, like where the door hinges where at.
I have an air compressor, no sanders yet (been holding off till I got close to think about painting), and an electric grinder. Just mention this because I saw an article where the guy started off down my path but switched to full bore, complete strip!! Plus the cab is currently off the truck and stripped down, no dash, or seat or anything, replaced the floorboards, and had another friend put new corners on by a couple rivets and then he brazed it. Never done bodywork before so keep that in mind to!!
And can I spray primer down and do little sanding myself?
I just want to get it prepped far enough that when I take it into maco or where ever, that there is minimum prep to paint, maybe have them do a once over on primer and sanding. Keep in mind, I'm not looking for the show room, competition look. Just looks good, for the price, at least for a little while. And if I go 4 wheeling that twig that just went down the side, didn't just ruin a $3k paint job! Wouldn't be happy, but..... you know, didn't pay $3k for a paint job either!!
Thanks!!
Rompin
P.S.,i used a good soft type wire wheel on my 4 1/2" ELECTRIC GRINDER TO REMOVE SURFACE RUST,gets most of the rust off & a little out of the pits with out taking any metal off,just make sure you run over those spots with a sander after words because the wire wheel tends to "polish" the metal also
I guess it doesn't matter what course of sandpaper I use to get the old paint off to get it down to the primer. Just when I add my sealer/primer to get ready to paint it, right?
Thanks again!!
Rompin 78
There are some spots on the hood and on the roof of the cab, that someone did a really shotty job of what looks like bondo.
Should I remove all the bondo all the way down to the metal, use some kind of etching primer, then re-patch (probably with bondo) then primer, then ultimately paint?
or
sand off the paint they put on, re-patch till is smooth and then primer?
I guess the really what I am asking what you would you do, if you noticed a shotty bondo job? Keeping in mind my skills and tools!
Thanks FordCwazyGuy!!
Rompin
