Rust terminating products?
Old Apr 7, 2004 | 07:40 PM
gktbay's Avatar
gktbay
Hello my FTE friends!
Any experiences with the rust killers ... paint on, spray on, dip?
I heard some good stories, yet no actual testimonials --- help me with product recommondations please.
Thanks in advance!
Old Apr 7, 2004 | 08:00 PM
fordaholic-67F100's Avatar
fordaholic-67F100
I use a small sandblaster and then treat it with (ospo). I get mine at the local hardware store.
Old Apr 7, 2004 | 09:00 PM
Carlene's Avatar
Carlene
Admom
Hi Greg - long time no hear.
I agree with Fordaholic as far as the blasting and Ospho - I can get a gallon of Ospho at Home depot for $10-$15. Cheap compared to other products out there.
What to put over it depends on what part you're doing. If it's something like the frame and you want it to not rust and look good, then I'd recommend something like POR-15 or ZeroRust. We've used POR on most all of our non-visable parts becaues that's what we found first. Heard many good things about ZeroRust also, but have never tried it. I hear it works the same as POR as far as one step protection, just doesn't have the harmful isocyanates in it. We picked up the POR a couple years back at one of the Turkey Rod Runs. I've sprayed it, bristle brushed it and spounge brushed it on and when it dries the results are very nice.
If you're talking about the actual body parts, that's a different direction. I'd still go with the Ospho for protection, but you should use regular auto paints/primers to cover and protect.
Old Apr 9, 2004 | 12:08 AM
stoutford's Avatar
stoutford
Try Rustmort, made by SEM. It is acidic and you paint it on with a brush. It turns black when it cures, An excellent product which i highly recommened. You can also prime and paint over it, but its best used on unseen body panels.
Old Apr 11, 2004 | 06:31 AM
68torino's Avatar
68torino
Glad to hear about someone using Rustmort. I had seen it and wanted to tryit out. Thanks!
Old Apr 11, 2004 | 07:02 PM
Aekisu's Avatar
Aekisu
<cr>
I use Rust Mort and Metal Ready (by Por 15). Happy with both of them. Some people swear by Picklex.
Old Apr 29, 2004 | 09:12 PM
gktbay's Avatar
gktbay
Thanks folks!
Need to kill rust starting to develop where the top of cab meets drip edge. Hope to apply from inner side and win the battle.
Old Apr 29, 2004 | 11:44 PM
dixon18's Avatar
dixon18
Man it's tough to beat rust that's in a seam. Although Rust mort is a great product, I think your lookin at blasting my friend.
Chris
Alberta
Old Apr 30, 2004 | 10:11 AM
TJC1989's Avatar
TJC1989
I have used a product called " Extend " They make a couple of versions of it. One coats, and the other hardens to the point od sandability, and primering. In a seam, where you can't sand is a problem. If you blast it, you may create some pretty big holes to worry about. Hey, rust is the pits to deal with. Especially the cancerous kind. Surface rust is not too bad, but the deep stuff is hard to stop.
