AC will blow through the dash air vents and then the defrost vents
#31
2007 F350 Air through Defrost
Don’t know what else to try.
I’ve done everything in this thread. Air still blows through defrost. Here’s a summary.
Air blows cool just through defrost so system charge is good and compressor is working.
Checked all vacuum lines, under hood and under dash. Also canister. No leaks.
Capped off the line going to the hubs.
Tried Capoing off solenoid but no change.
Blender works.
Air would blow a little through dash vents at first, now just completely from defrost.
What else could be causing this problem?
electrical?
if the relay was bad wouldn’t that cause the compressor not to work?
Can it be the AC controls?
Blender works.
electrical?
Last edited by TexManSanchez; 05-01-2018 at 01:25 PM. Reason: Additional information
#32
#35
#38
#39
