1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
AC will blow through the dash air vents and then the defrost vents
  #31
Old 05-01-2018, 10:29 AM
TexManSanchez's Avatar
TexManSanchez
TexManSanchez is offline
2007 F350 Air through Defrost
Don’t know what else to try.
I’ve done everything in this thread. Air still blows through defrost. Here’s a summary.
Air blows cool just through defrost so system charge is good and compressor is working.
Checked all vacuum lines, under hood and under dash. Also canister. No leaks.
Capped off the line going to the hubs.
Tried Capoing off solenoid but no change.
Blender works.
Air would blow a little through dash vents at first, now just completely from defrost.
What else could be causing this problem?
electrical?
if the relay was bad wouldn’t that cause the compressor not to work?
Can it be the AC controls?
Last edited by TexManSanchez; 05-01-2018 at 01:25 PM. Reason: Additional information
  #32
Old 05-01-2018, 12:41 PM
alloro's Avatar
alloro
alloro is offline
Received 4,212 Likes on 2,453 Posts
Have you tested for vacuum at the selector switch?
  #33
Old 05-01-2018, 01:31 PM
TexManSanchez
Forgive my ignorance but selector switch?
  #34
Old 05-01-2018, 07:55 PM
TexManSanchez
I found the problem. Looks like it’s the Vacuum Solenoid. Funny thing is I had already replaced it.
Crappy part I guess. Anyways. Gonna bypass the solenoid for now.
  #35
Old 05-02-2018, 03:52 PM
alloro's Avatar
alloro
alloro is offline
The Vent, Defrost, AC, Floor, Etc. selector switch.
  #36
Old 06-12-2018, 10:56 AM
tx_armadillo's Avatar
tx_armadillo
tx_armadillo is offline
I had the same issue. It’s was a bad EATC control head. Replaced and worked fine.
  #37
Old 06-24-2018, 11:31 AM
Danny87's Avatar
Danny87
Danny87 is offline
Im having an issue where the ac will blow out of the defrosters under hard acceleration, I put the eatc in self test mode but I dont think it gave me any errors.
  #38
Old 06-24-2018, 11:48 AM
tx_armadillo
The circuit board thing with the 4 looking tubes inside the ETAC connected to the main ETAC circuit board is the culprit. I had two ETAC control heads and just started troubleshooting and found that that was the issue.
Or just find a new one.
  #39
Old 06-24-2018, 05:57 PM
Danny87's Avatar
Danny87
Danny87 is offline
Would anyone mind taking a few pictures of the vacuum lines near the battery? I was looking over mine, but I'm not getting the warm and fuzzy that they are routed correctly, theres like 2 aftermarket t fittings that are connected together.
ithaca1230
07-19-2020 10:25 AM
02GrayPowerStroke
1997 - 2003 F150
07-28-2015 07:37 PM
Mr Dave73
1997 - 2003 F150
11-27-2010 01:41 PM
cajunbronco
1978 - 1996 Big Bronco
08-04-2003 07:37 AM
swenson
07-31-2002 02:12 PM
Quick Reply: AC will blow through the dash air vents and then the defrost vents
