AC will blow through the dash air vents and then the defrost vents
Any ideas where they vacuum leak or what might be the issue?
If I step on the gas the ac will go from blowing from the dash vents to the defrost vent and then if I let off the gas alittle it will blow back through the dash vents. Makes for a long hot ride.
I found no other vacuum leaks under the hood. Am I goinh to have to take the dash apart to find the other vacuum items?
It is starting to get hot here in Texas and I need to fix this ASAP.
Did you follow it in both direction to look for other points of damage? Once the vacuum line is penetrated by the corrosion, the corrosion can then run down the inside of the vacuum line and accumulate at a low spot until it eats through the line at that low spot.
I didn't see any other bad house.
The dash vacuum manifold is located at the forward end of the center console below the dash. It's where electrical signals from the climate control are translated into mechanical vacuum controls. It's possible this thing has burned up. When I changed mine out I found it was pretty brown from the electrical heat that's generated there. So my guess is they weren't built to last forever. You have to pull the center console out to gain access to the unit. The part number was 2L1Z-19D611-AA and I think it was about $75.
-Mike
-Mike
The O-rings are inside the control unit,
Read post # 11 This is the one I used to repair mine (sorry used to be pics). there is some good pics here, Or complete a google list... ford eatc o rings
It is easier than it looks, the pics and steps sound worse than they are. Just be sure to get the correct o-rings, I got mine from a hydraulic hose builder.
Jason that is the hot water valve that regulates hot water to the heater core for the climate control. It commonly gets knocked off when people change the sparkplugs or work in that area. Just check that the little vacuum line is correctly attached and not cracked or broken anywhere. Also check the vacuum line that runs under the batter tray that alloro was talking about and the operation of the check valve in that line. If the check valve is bad you will get the loss of vacuum under acceleration as well. I switched to an Optima battery a long time ago to avoid the corrosive battery issues. If all the lines check out the remaining culprit is usually the vacuum control solenoid, that I posted above. The O-rings that others have mentioned are inside that if you want to try your luck rebuilding it with the correct silicone O-rings.
-Mike
-Mike
-Mike
-Mike
It started out blowing out the bash vents but when I stepped on the gas it would stop. Now it is JUST the defrost vents and the floor.
I really don't want to take it to the dealer to have this looked at..
I don't blame you, it could take them hours to find the vacuum leak. At this point you've check all of the obvious things, so it's time to roll up your sleeves and dig into it. I suggest getting a handheld vacuum pump and just start testing everything for leaks.
