1978 - 1996 Big Bronco
Block Fitting size?
Old Jun 4, 2003 | 10:24 PM
BB94's Avatar
BB94
Block Fitting size?
Hey all...
Ive been following the boards a while, And i post most of the time on the other FS boards as Drilim.
I have a question regarding gauges. If i hook up a mechanical oil psi guage, and use a T connector to keep both the stock sender and guage and the the after-market guage, What is the dimensions of the T connector i need to get?
Basically, What is the size of the fitting into the block?
Also, What is the fitting at the radiator?...Id like to install a tranny temp gauge as well. Also, Where can i splice it under the dash to have the lights go on and off when i turn on the headlights?
Thanks A Ton.
Old Jun 5, 2003 | 11:19 AM
steve83's Avatar
steve83
Block Fitting size?
It's a pipe thread; probably 1/2" or 3/8" NPT. But the mechanical one will probably be different, so you may need an adapter for it. The t-fitting will probably have 3 female threads, so you'll need a close nipple, too, to join it to the block.
The dash illumination circuit is the LB/R wire that runs to the A/C control panel & ashtray, and you can tap into it anywhere you see that wire.
