Need help with engine noise
Old Apr 15, 2013 | 02:51 PM
scw78's Avatar
scw78
I have a noise from the front of then engine that I can't identify. It sounds to me like a bearing in a pulley going bad, kind of a metallic sounding rattle. What's throwing me off is I don't hear it all of the time. Sometimes I can't hear it at all, its louder at sometimes than at others and sometimes I can hear it spinning down after I shut off the engine. I can't isolate or identify anything that makes it start or stop (hot, cold, A/C on/off, etc...)
Any ideas??
Old Apr 15, 2013 | 03:04 PM
npccpartsman's Avatar
npccpartsman
That sounds like the turbo and it's possible that the noise is being transmittd down the air filter making it sound like the front of the engine. Pull the air filter tube from the front of the turbo and check the impeller for slack or rubbing against the housing--it will have a tiny bit of slack. You may just be hearing the turbo spin down. they can be "noisy" normally.
cowboyfordlord
16
Dec 5, 2012 10:02 PM
wezol5484
Mar 27, 2012 09:59 AM
BigJake34452
Mar 8, 2010 09:56 PM
99powerstrokeSD
Aug 17, 2006 08:19 PM
Cannonball01
Aug 10, 2004 11:12 PM
