WHERE IS MY COOLANT GOING?!?!?!
Old Apr 15, 2013 | 02:27 PM
thejim42's Avatar
thejim42
Last week i was checking fluids in my 94 f150 2wd with the 302 and noticed my coolant reservoir was empty...i filled it to the fill line and thought i was goodto go. I checked my fluids yesterday and it was empty again i filled it up this morning before i left for school, drove 5 miles to school and guess what NO COOLANT...it doesnt overheat, the heat still blows nice and hot (not that i need it) and i cant see anything dripping from anywhere. WHERE IS IT GOING?!?!?!?!?!?!?
Old Apr 15, 2013 | 02:58 PM
Fastback460's Avatar
Fastback460
I had the same problem with mine. I eventually found hairline crack in the bottom of the radiator which was dripping on the frame underneath the radiator, which is why I never saw any coolant on the ground. When I took the radiator out I noticed it had a LOT of mud in it, so what I think might have happened is when that mud froze over the winter it might have caused it to crack.
Old Apr 15, 2013 | 03:01 PM
blue924.9's Avatar
blue924.9
is there any smoke coming out of the exhaust indicating that its burning it?
Old Apr 15, 2013 | 03:08 PM
thejim42's Avatar
thejim42
Why would i lose it that fast? Though if im burning
it and wouldn't a cracked radiator cause me to have overheating issues?
Old Apr 15, 2013 | 03:13 PM
blue924.9's Avatar
blue924.9
well depends on how bad the leak is, not if you drive it a short distance. have you tried draining or checking the oil to see if its in there?
Old Apr 15, 2013 | 03:14 PM
lew52's Avatar
lew52
Start with pressure testing the cooling system and radiator cap....
Old Apr 15, 2013 | 03:50 PM
Fastback460
Mine went on for awhile before I found the leak, and it never had any overheating issues. But like I said, mine was just a hairline crack that slowly leaked out. The reservoir was always empty, but the radiator always had enough coolant in it to keep it from overheating.
Old Apr 15, 2013 | 04:17 PM
thejim42's Avatar
thejim42
I drive 300 miles a week and i just changed my oil
Old Apr 15, 2013 | 08:34 PM
irhunter's Avatar
irhunter
Lew has it right. Some AutoZone and Advance Parts will loan pressure testers for free.
Old Apr 15, 2013 | 09:06 PM
blkF250HD's Avatar
blkF250HD
Are you adding coolant directly to the radiator, or just filling the overflow? You need to fill and bleed the system and pressure check it. You could have a leaking radiator, water pump, timing cover gasket, intake gasket, etc.
Old Apr 15, 2013 | 10:23 PM
thejim42's Avatar
thejim42
The radiator only has a pressure cap...i filled the overflow one more time and the whining i thought was my alternator stopped (must have been the water pump) and i havent had a problem so far and i drove 50 miles...guess we will see tomorrow...gotta find that leak
Old Apr 15, 2013 | 11:02 PM
White 97 xlt's Avatar
White 97 xlt
Look for your leak at the weep hole on the bottom of the water pump (behind the pulley)
That whining sounds like a bad bearing, so the seal can't be far behind!!!
Old Apr 16, 2013 | 04:14 AM
tjc transport's Avatar
tjc transport
i ain't rite
plus, there most likely is a crack in the overflow bottle. you check coolant by filling the radiator when cold, not filling the overflow bottle.
you can have a full overflow and an empty radiator.
if the bottle is always empty, but the radiator is always full, don't worry about it.
the bottle in my 88 has had a hole in it for the past 300,000 miles.bottle is always empty, and the radiator is always full.
Old Apr 16, 2013 | 11:31 AM
thejim42's Avatar
thejim42
where do i fill the radiator? i can only find a pressure relief cap that wont come completely off. i filled the bottle 3 times before it finally started staying full. i think since i just turned 140k its probably time to change the water pump. especially if i have been running it low on coolant and burned up the bearings (probably why its whining at me) i still cant find a leak anywhere though
Old Apr 16, 2013 | 12:12 PM
lew52's Avatar
lew52
....Wow ...thats the funniest thing i have heard on this forum in a long time , on offense but i think you should take your truck to a mechanic or buy a bicycle LOL....
