LED LIGHT BARS
Old 04-01-2012, 03:38 PM
BigDaddy4x4's Avatar
BigDaddy4x4
BigDaddy4x4 is offline
Thumbs up LED LIGHT BARS
Hey Guys
Have you seen these?
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
One member on this forum got a few of them for his truck and he loves them.
https://www.ford-trucks.com/forums/1...y-truck-2.html
Old 04-23-2012, 04:07 PM
TXtinct's Avatar
TXtinct
TXtinct is offline
You'll shoot your eye out
Those are pretty cool, I've had my eye on the 30" version of that...
Old 06-18-2012, 07:06 AM
heymrdj's Avatar
heymrdj
heymrdj is offline
I am dubious to their quality. That heatsink isn't big enough to cool 40 3W LEDS to proper temps, especially mounted low to the ground on a hot summer day. It is aluminum at least, so it shouldn't get damaged badly by salt spray. I'd still run another bead of silicone on it for protection, I've seen many many lightbars get eaten up by salt spray.
Old 06-18-2012, 12:46 PM
JerzeyX's Avatar
JerzeyX
JerzeyX is offline
Those are neat.. A bit too pricey for me..
Old 06-19-2012, 12:29 PM
parkland's Avatar
parkland
parkland is online now
One thing I can tell you guys.... I import a ton of LED lighting for my business, and I can tell you that not every LED product stands up to what you would expect from quality LED's.
You will notice that a lot are rated "100,000 hours" for example, little did I know, and learned the hard way, that they are allowed to produce 50% of the original light by that time... and many do a lot sooner.
Now, every time I consider buying a product in bulk, I get a sample, take it apart, contact the orignal LED maker, find out the current and voltage specs, and test the power supply used on the module. 90% of the time LED's are over-driven to get more light, but they will start fading quickly.
Also be very careful with LED inside cheap fixtures.... moisture will gather and it will be end of story. There are a lot of LED fixtures or complete units that claim to be waterproof, and within a year or so might have moisture in them.
The best design I've ever seen was the LED;s in an aluminum channel, filled with epoxy. Solid as a rock, and zero chances for water to get in.
All this being said, I don't have any recommendations, or bad companies or products to point out, just thought I'd share this.
Old 12-20-2013, 10:53 AM
HiFivinMofo's Avatar
HiFivinMofo
HiFivinMofo is offline
I got a 50" Rigid LED bar. Wouldn't recommend the cheaper ones they leak after a while...
SHOpar
6.7L Power Stroke Diesel
04-08-2016 03:09 PM
ForemanES
28
04-25-2013 11:53 PM
Fomoko1
11-07-2007 11:28 PM
Storm
1999 to 2016 Super Duty
02-13-2007 07:17 PM
Whopper809
01-14-2006 02:49 PM
Quick Reply: LED LIGHT BARS
