monitoring system
Old Apr 14, 2013 | 11:40 PM
cole.nelson's Avatar
cole.nelson
monitoring system
Looking to buy a monitoring system for my 6.0 powerstrok
Old Apr 14, 2013 | 11:57 PM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
Scanguage 2 comes highly recommended. Also if you have an android device the Torque app is used by alot. For higher end (more flashy) people use the Edge CTS monitor. There is dash boss which is for Iphone and Ipad. Cheapest to highest Id say Torque ($5), Scanguage 2 ($160 or less), Dash Boss (not sure of price), Edge CTS ($300+/-).
Old Apr 15, 2013 | 12:05 AM
04badford's Avatar
04badford
Hey Cole welcome to FTE, most us the Scan GaugeII or dash boss theres a few others, the best price Ive seen so far is the scan gauge for 160.00 at auto zone you can probebly get it a little cheeper on line , as far as the dash boss ? I havent owned one , but some of the other guys will , Take a look at my Thread,(do we get a commision) and theres good info there. on all of the scans to monitor live data. good luck and happy reading.
Scan Gauge II with x gauge will look at = all senser related problems , it shows oil and coolent temp,trans, icp,ipr,map,egr,tps,batts,alt,ficm, and alot more best bang for your buck
it does not show fuel pressure
Old Apr 15, 2013 | 12:06 AM
cole.nelson
Ill have to look into that torque again. I found out about last night. Just looking for something just a bit nicer. Im trying to stash my money so I can bulletproof my truck this summer.
Old Apr 15, 2013 | 12:10 AM
mustang_309's Avatar
mustang_309
I wouldn't suggest the Edge insight until they add some of the more important pid's, Dashboss is way cool if you have an IOS phone or iPad or scangauge II would be your best options
Old Apr 15, 2013 | 12:22 AM
BLADE35's Avatar
BLADE35
Welcome to FTE
I would agree with all the Above
I use SGII it picks up everything on engine some trans and will do what you need
DashBoss Another good one I really like the DB Display plus I think it has a Port to add Fuel Pres gauge input
There are no OEM Senders for LPO,EGT,Fuel Pressure so no matter the Gauge you get these gauges will require Senders or basicaly everything so starting from Scratch
Old Apr 15, 2013 | 12:15 PM
diesel_dan's Avatar
diesel_dan
If you have a droid phone (or you can just buy a droid device cheap) by far the best bang for your buck is the Torque Pro. It's graphical interface is quite a bit nicer than a text based one like SGII. I'm in to mine for about $18 -- that's the cost of a bluetooth adapter for the ODBII port and $4.95 for the app (I already have the phone).
You can set up some very nice dashboards with different style gauges, it monitors, alarms and has all the Ford extended PIDs.
Do some searches on Torque and read the threads, there's some nice screen shots of what you can do...
Old Apr 15, 2013 | 12:56 PM
2003 EXCURSION's Avatar
2003 EXCURSION
Originally Posted by BLADE35
Welcome to FTE
I just got my dashboss going (and absolutely love it), so Im just getting it figured out. Dashboss has the senders available for EGT and fuel pressure, which I plan to order shortly and add to it, but you only have the ability to add two other inputs to it. I know there is no LPO, but I find no HPO either. Is that because I am not recognising it, or is that because my '03 does not have it, whereas later years do?
By the way, for the record, I have no experience with the others so I can't comment on which is necessarily better. I thought it looked like a great choice from my research, already had an Ipad, and am about to buy an Iphone.
Old Apr 15, 2013 | 02:50 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
Does it really have all of the Ford enhanced PID's? If so, that is an amazing deal. There are over 6,000 Ford enhanced PID possibilities. The actual number you can monitor depends on how many the PCM monitors. HERE is a full list of Ford enhanced PID's. Most devices such as AE, IDS, Snap On Solus, and our Infinity, require some sort of license or add-on to monitor all of the enhanced parameters.
For example, our Infinity will monitor 254 signals on my 2001 7.3L, and 336 signals on my fathers 2004 6.0L. This is, of course, with a VIN license.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Apr 15, 2013 | 03:08 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Another vote for Dashboss. It has the most available parameters without having to use a laptop like AE.
Cheap route would be Torque.
Scangauge is good, but still has that 80s pocket calculator look to it and can only show 4 parameters at a time.
Josh
Old Apr 15, 2013 | 03:14 PM
Justin@DP-Tuner
PREMIUM SPONSOR
Josh
I beg to differ. How many does it have available?
__________________
Justin
www.dp-tuner.com
Old Apr 15, 2013 | 04:02 PM
Bullitt390's Avatar
Bullitt390
Do you ever wonder why you're always on the defense?
Was I comparing DB to whatever crap you pan-handle? It was a comparison of DB, SG, Torque and Edge.
Josh
Old Apr 15, 2013 | 04:49 PM
BLADE35's Avatar
BLADE35
Guys it didnt need to come to fight that Fast
Theres no use getting worked up over some Stupid gauges
Old Apr 15, 2013 | 04:55 PM
BLADE35's Avatar
BLADE35
[quote=2003 EXCURSION;13067014]I just got my dashboss going (and absolutely love it), so Im just getting it figured out. Dashboss has the senders available for EGT and fuel pressure, which I plan to order shortly and add to it, but you only have the ability to add two other inputs to it. I know there is no LPO, but I find no HPO either. Is that because I am not recognising it, or is that because my '03 does not have it, whereas later years do?
quote]
Yes your DashBoss has HPO Gauges
You should get ALL HPO Gauges with DB for 2003 in fact ALL Years 6.0L
I dont know how to go about working the DB to get what you want IT Will Do it though
Josh is the Guy to ask for help getting the HPO Gauges working on your DB
Old Apr 15, 2013 | 04:58 PM
diesel_dan's Avatar
diesel_dan
I edited my statement. It's great that you are a site supporter, but you sure come off as a hot head -- how's that workin' for you business-wise?!
