E99 4WD CC Front-End Part Numbers?
Old Apr 14, 2013 | 07:19 PM
nlemerise's Avatar
nlemerise
After completing 2200 miles this week, I am certain that I want to replace everything that is a maintenance item on the front end. I'd like to use the best in parts. As of now, I have the following parts I will need:
tie-rod ends
sway bar bushings
end links (or bushings)
adjust steering box
Does anyone have the part numbers available that they could post...also any other parts that I might replace while I am in there? Thanks guys !
Old Apr 14, 2013 | 08:43 PM
caverjoe's Avatar
caverjoe
subscribing. I would also like this info.
Old Apr 14, 2013 | 09:40 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I am going to be doing the same. I am going with XRF parts. They can be had in a kit from thetireclub.com or cheaper individually from mibearings.com.
Here is a very helpful post I have saved for when I do mine.
Originally Posted by F350-6
So I've been looking around and here's what I've come up with so far.
Tireclub sells the kit for $299.00 on this page The Tire Club
I'm not really sure I need new adjusting sleeves so I decided to just price the parts individually. Don't waste your time. It's more money to not buy the kit. I did notice that they called their parts "problem solver" on the tireclub website. That kind of bothers me since that's exactly what MOOG called their pieces I bought and had such poor luck with. Someone please tell me these are not just private labeled Moog parts.
I also used google to see if I could find any other XRF dealers and came up with MIBearings LLC, Wheel Bearings, Brake Parts, and More
When I entered the part numbers in their website, I noticed it was quite a bit cheaper. And this includes the adjusting sleeves which I probably won't buy.
Total Items: 6 Weight: 47.06lbs Amount: $210.37
<table id="cartContentsDisplay" border="0" cellpadding="0" cellspacing="0" width="100%"> <tbody><tr class="tableHeading"> <th scope="col" id="scQuantityHeading">Qty.</th> <th scope="col" id="scUpdateQuantity">
</th> <th scope="col" id="scProductsHeading">Item Name</th> <th scope="col" id="scUnitHeading">Unit</th> <th scope="col" id="scTotalHeading">Total</th> <th scope="col" id="scRemoveHeading">
</th> </tr> <tr class="rowEven"> <td class="cartQuantity"> <input name="cart_quantity[]" value="1" size="4" type="text">
</td> <td class="cartQuantityUpdate"> <input src="http://mibearings.com/includes/templates/glacial_age/buttons/english/button_update_cart.gif" alt="Change your quantity by highlighting the number in the box, correcting the quantity and clicking this button." title=" Change your quantity by highlighting the number in the box, correcting the quantity and clicking this button. " type="image"> </td> <td class="cartProductDisplay"> XRF DS1438, DS1438, 410-1065, DS1438 DRAG LINK
</td> <td class="cartUnitDisplay">$55.25</td> <td class="cartTotalDisplay">$55.25</td> <td class="cartRemoveItemDisplay"> <input name="cart_delete[]" value="43093" type="checkbox"></td> </tr> <tr class="rowOdd"> <td class="cartQuantity"> <input name="cart_quantity[]" value="1" size="4" type="text">
</td> <td class="cartQuantityUpdate"> <input src="http://mibearings.com/includes/templates/glacial_age/buttons/english/button_update_cart.gif" alt="Change your quantity by highlighting the number in the box, correcting the quantity and clicking this button." title=" Change your quantity by highlighting the number in the box, correcting the quantity and clicking this button. " type="image"> </td> <td class="cartProductDisplay"> XRF ES3423, ES3423, 401-1744, ES3423 TIE ROD END
</td> <td class="cartUnitDisplay">$28.51</td> <td class="cartTotalDisplay">$28.51</td> <td class="cartRemoveItemDisplay"> <input name="cart_delete[]" value="42509" type="checkbox"></td> </tr> <tr class="rowEven"> <td class="cartQuantity"> <input name="cart_quantity[]" value="1" size="4" type="text">
</td> <td class="cartQuantityUpdate"> <input src="http://mibearings.com/includes/templates/glacial_age/buttons/english/button_update_cart.gif" alt="Change your quantity by highlighting the number in the box, correcting the quantity and clicking this button." title=" Change your quantity by highlighting the number in the box, correcting the quantity and clicking this button. " type="image"> </td> <td class="cartProductDisplay"> XRF ES3427T, ES3427, 401-1741, ES3427 TIE ROD END
</td> <td class="cartUnitDisplay">$21.14</td> <td class="cartTotalDisplay">$21.14</td> <td class="cartRemoveItemDisplay"> <input name="cart_delete[]" value="41925" type="checkbox"></td> </tr> <tr class="rowOdd"> <td class="cartQuantity"> <input name="cart_quantity[]" value="1" size="4" type="text">
</td> <td class="cartQuantityUpdate"> <input src="http://mibearings.com/includes/templates/glacial_age/buttons/english/button_update_cart.gif" alt="Change your quantity by highlighting the number in the box, correcting the quantity and clicking this button." title=" Change your quantity by highlighting the number in the box, correcting the quantity and clicking this button. " type="image"> </td> <td class="cartProductDisplay"> XRF DS1439, DS1439, 410-1066, DS1439 DRAG LINK
</td> <td class="cartUnitDisplay">$83.46</td> <td class="cartTotalDisplay">$83.46</td> <td class="cartRemoveItemDisplay"> <input name="cart_delete[]" value="43152" type="checkbox"></td> </tr> <tr class="rowEven"> <td class="cartQuantity"> <input name="cart_quantity[]" value="1" size="4" type="text">
</td> <td class="cartQuantityUpdate"> <input src="http://mibearings.com/includes/templates/glacial_age/buttons/english/button_update_cart.gif" alt="Change your quantity by highlighting the number in the box, correcting the quantity and clicking this button." title=" Change your quantity by highlighting the number in the box, correcting the quantity and clicking this button. " type="image"> </td> <td class="cartProductDisplay"> XRF ES3422S, ES3422S, 425-1051, ES3422S ADJUSTER SLEEVE
</td> <td class="cartUnitDisplay">$12.26</td> <td class="cartTotalDisplay">$12.26</td> <td class="cartRemoveItemDisplay"> <input name="cart_delete[]" value="40666" type="checkbox"></td> </tr> <tr class="rowOdd"> <td class="cartQuantity"> <input name="cart_quantity[]" value="1" size="4" type="text">
</td> <td class="cartQuantityUpdate"> <input src="http://mibearings.com/includes/templates/glacial_age/buttons/english/button_update_cart.gif" alt="Change your quantity by highlighting the number in the box, correcting the quantity and clicking this button." title=" Change your quantity by highlighting the number in the box, correcting the quantity and clicking this button. " type="image"> </td> <td class="cartProductDisplay"> XRF ES3426S, ES3426S, 425-1052, ES3426S ADJUSTER SLEEVE
</td> <td class="cartUnitDisplay">$9.75</td> <td class="cartTotalDisplay">$9.75</td> <td class="cartRemoveItemDisplay"> <input name="cart_delete[]" value="40371" type="checkbox"></td> </tr> </tbody></table> Sub-Total: $210.37
Rock Auto sells the Raybestos professional grade parts for a total of $315, but if the XRF are just moog problem solvers, I may go that route. Otherwise I'll just save $100 and go with the XRF from MIBearings.
Can anyone come up with anything on google before I place an order?
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Woops... Just realized you specified E99. Not sure if these are different, I know there were changes.
Old Apr 15, 2013 | 02:53 PM
nlemerise's Avatar
nlemerise
Thanks for the list of replaceable parts, Trey...now anyone have E99 parts numbers?
Old Apr 15, 2013 | 08:23 PM
tappit01's Avatar
tappit01
bump... i'm sure i'll be needed this info myself.
Old Apr 16, 2013 | 09:24 PM
caverjoe's Avatar
caverjoe
Dang..... I was getting excited for a min. damn early in my 99
John7894
Dec 27, 2008 12:30 AM
ScottInTexas
Jul 10, 2006 07:34 PM
mtpcage
Mar 15, 2006 08:08 AM
OC Ford
Aug 10, 2005 11:43 PM
gjf250
Aug 4, 2004 09:35 PM
