Looks like a good place for a bumper sticker if you can't find a used emblem.
People really suck sometime. I can't imagine why anyone would want an Econoline 350 emblem unless they a status symbol in Norway (where I imagine gasoline costs about as much as good wine).
The first one you linked to was quite cool looking.
I found one that had the exact 10" long Econoline name, and how would it look with the E-350 superduty bagde below.
The E-350 superduty bagde is the one with the superduty name in small letters below. Maybe it's too big in size?
I show Ford's p/n as: F1UZ-1542528 D if I understand my crash book correctly.
Here's a link to an eBay item, located in the USA:http://www.ebay.com/itm/NOS-OEM-Ford-E150-E250-E350-Van-Club-Wagon-Chateau-Emblem-Nameplate-1997-98-/261150254248?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ccdc4a4a8&vxp=mtr
If you find such an item here and the seller won't ship overseas I'd be glad to act as your intermediary if that would be helpful.
Thanks JWA, but I don't have a club wagon chateau
But the badge would probably fit
Shipping is no problem for me, but thanks.
Here is a photo of the side windows from when I found it, half burried in sand.
Any other name badges for this window set-up, or is it just Econoline e-350?
That van started life as a cargo van, so it would have bore no badges other than the standard Econoline E350 badge, and possibly a converters name plate.
Some *******s in a parking lot in downtown Oslo (Norway) swiped my rear badge
The rear badge on my Club Wagon fell off all on its own after the aging factory installed adhesive foam gave up the ghost. All that holds emblem on is die cut piece of thin foam that's got glue on both sides.
Your "Econoline 350" badge might be most EZ to replace with a good used item, if you can wait for one to turn up. If FORD discontinued it some dealers might still have NOS.
See E-350's from time to time in Self Serve junkyards, where emblems are often considered 'Pocket Candy' - If you can wait.
It was there when I parked the car, and I saw imediately it was missing when I returned. Even the scratches in paintwork around it tells the tale.
Inside the door i have 2 loose locking tabs rattling around. It was stuck on with adhesive foam as well.
Now all I have is the adhesive residue and 2 holes in the door, filled the holes with silicone sealant to keep the moisture out.
