Sponsored by: Auxito
Help 2003 F150 4.6L
Old Apr 13, 2013 | 10:25 AM
max1212's Avatar
max1212
Help 2003 F150 4.6L
Hi Guys, First time poster here, sure hope someone can help.....
Yesterday my 2003 F150 4.6L would not start. Noticed I couldn't hear the fuel pump coming on.I checked the fuses and then bench tested the fuel pump relay and it checks out ok. I also checked the fuel inertia switch and it wasn't tripped and then checked for power there and there is none. I also noticed where the mileage usually is just a bunch of dashes. I tried hooking up a scanner to read the codes and all I get is a link error. And oh yeah I also installed new fuel pump.So where do I go next? Could the problem be with the PCM?Anyway to check that?
Old Apr 13, 2013 | 07:23 PM
Bluegrass 7's Avatar
Bluegrass 7
High likelyhood the dash fault has cause the PATS system to disallow starting.
Try this first; turn on the ignition to run and wait several minutes to see if the Theft lamp flashes a two digit code.
There is a second test but try this one first.
It may be circuit board connections that is a known issue.
Good luck.
Old Apr 13, 2013 | 08:24 PM
max1212's Avatar
max1212
Yes after a few few minutes it flashes either a 16 or a 61....
Old Apr 13, 2013 | 10:35 PM
Bluegrass 7
The code would be 16.
It tells that the PATS signal in not being received by the PCM.
A fault in the wiring or the PATS Transceiver.
The two units are hardwired togather.
If the PCM does not receive a 'legal' signal from PATS, it suspend starting as it is supposed to do for Theft protection.
Unfortunetly it is the same for a fault.
Good luck.
Old Apr 14, 2013 | 07:05 AM
max1212's Avatar
max1212
Thanks for the help Bluegrass 7. By any chance have you ever had to change a PATS transceiver before?
Fungus232
21
Aug 19, 2022 02:17 PM
garyd
1997 - 2003 F150
Apr 30, 2017 06:39 PM
roger.carter
Apr 6, 2017 10:38 AM
sleazytiki
16
May 16, 2014 09:44 AM
jph9475
1997 - 2003 F150
Mar 24, 2013 09:19 AM
