Ford 521 stroker np435 Conversion
Old Apr 12, 2013 | 05:50 PM
GageC1993's Avatar
GageC1993
I bought a ford 521 stroker that was previously a 429. I also have a Np435 that i would love to hook it up with the Engine. From what i understand and have read im going to need to buy a Ford 400 Bellhousing but what puzzles me is that clutch and flywheel situation. After a few weeks of reading about the conversion i ran across this Kit from L&L
L&L Products
and need to know if this clutch would hold up to the 600hp the engine puts out. If not any point in the right direction would be greatly appreciated. Thank you in advance for the help.
Old Apr 12, 2013 | 10:12 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
First of all, A 521 is going to be a pretty tall order to build 600 hpon pump gas, not impossible, but probably well into the 6000 rpm range. My 545 is 11.2:1 aluminum headed and hits 6000 rpm, I might be 600 but not over for sure. Anyway, I would say that you will be fine to use that kit for your combo, L&L makes very nice stuff (except the engine mounts)
Old Apr 13, 2013 | 07:46 AM
Drac's Avatar
Drac
Save the old ones
Check out and search around these 2 sites.
More information than most men can handle.
460ford.com
network54.com/Forum/85220/
They know a thing or 2 bout getting the iron hot
Old Apr 13, 2013 | 09:51 AM
F-250 WARHORSE
X2 on what Drac said. Read and read and search and read and search. I learned a ton about my stuff from those boys. They are very good at the "385" from ford.
Old Apr 13, 2013 | 11:49 AM
GageC1993's Avatar
GageC1993
Thanks for the tips guys! Ill do that
Old Apr 15, 2013 | 11:14 AM
kevin316's Avatar
kevin316
I'm not sure why you think 600 hp will be tough to get out of a 521. I just built one and it will be in the 650 range on pump gas and it is only 10.1:1. It wouldn't be hard to get more than 650 hp out of it if I wanted to.
It's not cheap though, I have about $10,000 in my engine.
Old Apr 15, 2013 | 12:17 PM
turbohunter's Avatar
turbohunter
Aaaaaaaaaaaaaaaaaa
I wanna be you.
Old Apr 15, 2013 | 02:57 PM
Drac's Avatar
Drac
Save the old ones
Marc,
Looking at your list of toys, I wanna be you, but with time to drive them.
Hee hee
I understand the time thing. Cant seem to find enough time to finish my current project.
Old Apr 15, 2013 | 03:01 PM
turbohunter
We're such hooors
Old Apr 15, 2013 | 03:15 PM
GageC1993's Avatar
GageC1993
I have about the same into mine ($10,000).. Single kid living at home with a good job! Enjoying the freedom while I can! Runs premium fuel..
Old Apr 15, 2013 | 04:47 PM
kevin316's Avatar
kevin316
We have something in common then. I'm a married dad and my last kid just left home so now I can afford it. Funny how that works
Old Apr 15, 2013 | 11:41 PM
GageC1993's Avatar
GageC1993
Haha! My dad was telling me the other day to enjoy it while I can! So do you think that clutch kit will be good enough?
Old Apr 16, 2013 | 10:00 AM
kevin316's Avatar
kevin316
Sorry, can't help you there. I am going with a C6 auto in mine.
Old Apr 16, 2013 | 11:33 AM
turbohunter
If it was me I would be concerned about "slight rough engagement".
If its a toy and in the mud or off road at all times then Ok. Crawling trails might be a pain. I couldn't use that in my build. But you're not me.
I might contact them and see exactly what that means. They may have something better for you. I've found that direct contact with the manufacturer is always best. It's so easy these days, no big deal.
Good luck.
Old Apr 16, 2013 | 11:53 AM
Drac's Avatar
Drac
Save the old ones
Clutches slip due to torque, not so much because of hp.
Bigger diameter is better. 12" stronger than 11"
What does L&L say?
Another thing to ask about is the pressure plate spring force. Higher the pressure, stronger the clutch. It is harder on the left leg to push though.
