351M Identification?
Old Jun 4, 2003 | 07:15 PM
Wrecker's Avatar
Wrecker
How can I tell if the motor I am looking at is a 351M? What is the difference betweem a 351M and any other 351. There is a motor for sale that is advertised as a 351 ford with 65,000 miles (Out of vehicle), that I am considering, to replace my tired 400 in my 79 F250. Before I put any money into it I need to know if it will work in my truck. The motor is at an auction, so I wont be able to take it apart for inspection before purchase...
Thanks
Wrecker
Old Jun 5, 2003 | 09:04 AM
GT40man's Avatar
GT40man
ok all 335 engines have the water outlet on the block. 8 bolts on valve cover
the intake on a 351M/400 is @ 10.7 inches across
if these match, its either a 351M or a 400, the only real way to tell is the crank part number.
Old Jun 6, 2003 | 05:55 PM
Coondawg's Avatar
Coondawg
If it's a 351C or M the timing gear housing will be cast as part of the block. A 351W will be an aluminum piece like a 302.
351W has water neck on intake. Exhaust bolt holes run horizontally, like 302.
351C/M water neck is on the block, as previously mentioned; exhaust bolt holes run diagonally.
jas88
Aug 25, 2015 05:27 AM
jas88
Aug 24, 2015 04:49 PM
preppypyro
23
Feb 5, 2014 03:30 PM
Green Streak
1983 - 2012 Ranger & B-Series
Oct 23, 2003 05:33 PM
