Using Seafoam
Old Apr 12, 2013 | 03:16 AM
burton7.3's Avatar
burton7.3
Using Seafoam
Has anyone did Brake booster trick? I was told you can take the line off the brake booster and put it in the seafoam can and start the truck let it run for a Minute or two then turn it off put it back together and then let it set for 24 hours then start the truck and let it run in till it clears up
Old Apr 12, 2013 | 08:48 AM
gasman6674's Avatar
gasman6674
Any manifold vacumn source will work but only on a gasser. And you only need to let it set 30 minutes or so and make sure you do it outside as it is qiute smokey.
Old Apr 12, 2013 | 09:55 AM
burton7.3's Avatar
burton7.3
Seafoam
Ok thanks just ill be get a can and try it out
Old Apr 12, 2013 | 12:43 PM
83capril's Avatar
83capril
I did it thru the brake booster. Worked well, but when can was almost empty I killed the engine by putting those hose fully into the Seafoam. Let sit for about 30 minutes then drove it out into the country. Out there I did some high RPM driving to help clean out the carbon.
Old Apr 12, 2013 | 01:07 PM
burton7.3's Avatar
burton7.3
Thanks for the info
Old Apr 12, 2013 | 03:17 PM
ErinsFord's Avatar
ErinsFord
Never used it on the F150 but I used it on my 02 Subie and it smoked like crazy. Better to have 2 people, one with the seafoam and another revving the engine so you don't kill it.
Old Apr 12, 2013 | 03:40 PM
burton7.3's Avatar
burton7.3
Yea I just did it to my truck my Neighbor leave the same time smoke her out haha but it same to run better found out that I have a small exhaust leak
Old Apr 12, 2013 | 04:37 PM
tigerblood's Avatar
tigerblood
if its smoking like crazy, its working haha
Old Apr 12, 2013 | 04:57 PM
Jarryd's Avatar
Jarryd
I've had people ask what was wrong with my car when I do this.
Old Apr 12, 2013 | 05:05 PM
tigerblood's Avatar
tigerblood
do it in the walmart parking lot and see the looks you get. haha
Old Apr 12, 2013 | 05:30 PM
burton7.3's Avatar
burton7.3
How Often should you seafoam a engine
Christopher Workman
Apr 8, 2019 07:45 PM
rico56
Mar 17, 2017 02:52 PM
fixit5561
Mar 25, 2012 04:46 AM
Katmandu
Nov 23, 2005 07:43 PM
