Offroad & 4x4
BW1356 electric shift...
Old Jun 4, 2003 | 05:05 PM
javi2001's Avatar
javi2001
Hi all, my actual transfer BW1356 manual shift is dammage. I obtain a used low millage BW1356 electric shift to replace the old one, but I couldn't find the electronic controller. Someone knows how to obtain one or replace it by a different electronic controller???
Thanks
Old Jun 4, 2003 | 05:41 PM
bronco351's Avatar
bronco351
First off, we need to know what kind of vehicle it is. Also why do you want to put in a electric shift, instead of a manual shift?
Old Jun 4, 2003 | 05:42 PM
RRMike's Avatar
RRMike
Is your intention to convert your truck to electric shift. Is there not a way to pull the electric stuff off and bolt your shifter up to it?
Old Jun 4, 2003 | 05:43 PM
javi2001's Avatar
javi2001
Yes but is necessary disassembly both tranfers I really preffer electronic shift...
Old Jun 4, 2003 | 05:47 PM
RRMike's Avatar
RRMike
Oh I've never seen the kind with electric shift so I was just guessing. I would have thought that the solenoid that shifts it would just mount to the outside and could be removed and replaced by your shift linkage.
Too bad.
Old Jun 5, 2003 | 01:51 PM
steve83's Avatar
steve83
You can find the controller in a junkyard, but you'll also need a LOT of wiring harness, and you'll have to add some to your dash to make it work.
You never said what type of vehicle you drive.
Old Jun 5, 2003 | 11:10 PM
javi2001's Avatar
javi2001
Yes, well I don't have any problem whith Wiring. I'll take your idea.
Regards;
Old Jun 17, 2003 | 10:43 AM
javi2001's Avatar
javi2001
Upsss sorry, it is a F150, 1986, 300 CID Carb Engine + E4OD, Auto lock. I'm electronics technician thats why I prefferd electronic controllers than manual shift.
regards,
hjartland
Feb 7, 2017 12:30 PM
S-10 warrior
Sep 17, 2016 08:05 PM
masseysbronco
1978 - 1996 Big Bronco
Nov 16, 2011 12:22 AM
backfire14
Apr 8, 2010 04:15 PM
lisagoud
Sep 11, 2006 05:36 AM
