glow plug issues
Old Apr 10, 2013 | 11:03 AM
wtroger's Avatar
wtroger
glow plug issues
Father-in-laws truck 1996 f350 7.3 psd 105,000 miles he is 82 years old so don't bash for lack of maintenance. It is hard to start so I started checking the glow plug system. Relay I will replace it sometimes works sometimes doesn't. I disconnected the connectors at the valve covers and test the outer pins to check GP resistance. only 1 of 8 was close 1.5 ohms 5 show open 2 show high resistance 600meg 1.5 meg. So my question is this a harness issue or the GP's themselves. Or should I just shotgun this and replace all the components gp's harness, valve cover gaskets, relay. And where would be the best place to get the under valve cover harness assembly's. I will only use zd-11 glow plugs. If the harness is bad what do I need to look for when I open her up.
Old Apr 10, 2013 | 04:00 PM
farmert's Avatar
farmert
I would say that the glow plugs are the issue, 5 dead ones, 2 might be heating a little and 1 that is working. The under valve cover harness would have burned pins where it connects to the gasket if they are bad. I would just replace the plugs and inspect the harness and go from there. When I had issues, it was with the plugs on the engine side of the gasket.
Old Apr 10, 2013 | 06:04 PM
stainlessstroker95's Avatar
stainlessstroker95
You can get every thing you need from riff raff diesel or diesel o rings.
Old Apr 10, 2013 | 10:25 PM
wtroger's Avatar
wtroger
I ordered the Dorman gaskets and Zd-11 glow plugs. One plug was melted soi bought the gaskets with the wiring
Andy Sullivan
Aug 8, 2013 11:49 AM
santacruzf250
Apr 29, 2012 10:01 PM
Phy
25
May 26, 2011 06:32 AM
StevensPoint
Mar 26, 2008 12:18 PM
eric777
Feb 7, 2007 07:46 PM
