Was this a score?
Old Jun 4, 2003 | 04:46 PM
Frankenstang57's Avatar
Frankenstang57
Was this a score?
I went down to the local Pull-n-Save this weekend for the $30 all you can carry day. I picked up a set of DOVE-C heads for the sum of $15.(I split the $30 cost with my buddy) They are definately better than the D2VE heads I already have right? What are the different comp. ratios between the two? Thanx!
Old Jun 4, 2003 | 05:13 PM
airharley's Avatar
airharley
Was this a score?
You'll notice a few big difference in combustion chamber shape. The D0VE-C heads will be around 72-75 cc's vise you D2VE's which are around 95-99 cc's. Plus you get the screw in studs for the valve train. If you build them up you will notice a very big difference in CR and performance between the heads.
Old Jun 4, 2003 | 09:17 PM
Frankenstang57
Was this a score?
Woohoo, and you can't beat the price either! I did notice the difference in the rocker/studs, they don't seem as cheap. I grabbed the pushrods too, I figured there may be a difference in those also. Too bad I just went through my motor a couple of months ago. Oh well, it's worth it!
Old Jun 4, 2003 | 10:25 PM
merc460's Avatar
merc460
Was this a score?
That is a very good price for dove c heads
Old Jun 6, 2003 | 10:06 PM
Brian460's Avatar
Brian460
Was this a score?
Pushrods are a fairly cheap item I would recommend using new ones.
Greatwhite94
Jan 21, 2017 02:45 PM
OBS Mule
Jan 15, 2017 09:37 AM
TUFFY
Mar 9, 2004 08:20 PM
thewall
May 1, 2002 06:42 PM
