Sponsored by: Real Truck
Superduty Electrical Issues
Old Apr 10, 2013 | 07:59 AM
BluPhx's Avatar
BluPhx
Question Superduty Electrical Issues
I have (2) unrelated electrical issues.
Problem 1: My fuel gauge has started to act up. When I start my truck it pegs full, 10-15 minutes later it pegs empty. Sometimes it settles on 3/4 but eventually pegs again. This was an intermittent problem for awhile but now permanent. Obvious fix would be the sensor but since it is a Ford I want to make sure there isn't some other electrical nuance I should be checking.
Which leads me to my other problem. For the last several years I have had an intermittent short in the circuit that feeds my radio/windows/glove box light/cabin light. Driving down the road the radio will turn off for no reason. I use to think I couldn't recreate the short to troubleshoot until I realized that every time I try to turn on my cabin light the circuit goes dead (this isn't the case when I open the door and the light comes on). I've heard a lot of people have problems with the harness running across the door base.
Anyone with an "Oh yeah that happened to me once"?
Old Apr 10, 2013 | 10:01 AM
projectSHO89's Avatar
projectSHO89
You actually have an intermittent "open" circuit, not a "short" circuit. Shorts usually cause blown fuses or smoke when they occur.
Please identify the specifics of your truck so the circuits can be traced out.
Old Apr 11, 2013 | 07:52 AM
BluPhx's Avatar
BluPhx
2003 F250, 7.3L, Lariat edition
Old Apr 12, 2013 | 07:40 AM
99f350sd's Avatar
99f350sd
Replace the fuel sender. wiggle wires to find bad connection...
Dick
NS F250
26
Apr 17, 2021 05:49 AM
bekko
Nov 1, 2013 02:22 AM
dionisi58
Mar 3, 2010 02:54 PM
Jrigg
Jul 27, 2008 03:10 AM
sofdchief
Oct 23, 2007 06:52 PM
