1. Besides heavy duty payload and max tow what else do I need to make this a work truck? What gears are best? 80-90% of the time this will be my daily driver, and ecoboost fuel economy is probably the only reason I'm not looking at the superduty. I do drive with a light foot btw and usually set the cruise at around 50-55mph, right where the motor goes into overdrive.
2. My plan is to get a 20' car hauler with a GVWR of 10,000. That'll give me enough payload to move a small apartment going one way, and take a couple skids or a car coming home.
I checked out the trailers. If I want a car hauler with a solid ramp that can support a forklift for loading skids it'll be around 3500 pounds. That leaves 6500 payload.
Realistically how much car can I put in there without worrying about tongue weight?
with regard to gearing: max tow or max payload both come with the 3.73 gears (max tow can be had with the E-locker, max payload comes with the limited slip). max tow can be had with either the 6.2v8 or the ecoboost. max payload can be had with either the 5.0v8 or the ecoboost.
so, in a nutshell, if you want a max payload/max tow, you get the ecoboost with 3.73 LS. which is what i think you said you were wanting.
as for how much car you can load, you should be fine with anything that does not overload you trailer. your hitch should be rated to 1100lbs tongue weight with the weight distributing hitch. being a vehicle, you probably have some flexibility on how far forward you load it.
just make sure it is far enough forward to put a fair amount of weight on the truck, then adjust your WD hitch to accommodate the load you have.
6500lbs should give you enough to load a regular crew cab 1/2 ton pickup, which is nice. FWIW, i drove my 83 k20 across a scale and with me in it it weighed in right at 5350, putting the truck right at 5200 (wet).
i'm not sure if that really answers you questions or not. if not, let me know and i'll try again.
any f150 with any trailer tow package comes with a receiver hitch. max tow gets an upgraded bumper to help support the additional weight. max tow also comes with extendable towing mirrors.
do not entertain the idea of getting a truck without the factory tow package and letting the dealer add the receiver hitch. if you go that route you will miss out on alot of goodies that the towing package comes with.
everything you ever wanted to know, and probably a little more, should be there for your reading and viewing pleasure. everything from picking the right type to installation and setup is there, so it is a very good place to get started. usually their prices are pretty competitive too, but you could also get everything you need at a local RV dealer.
I tow a 20' 7500lb enclosed race trailer ever single weekend to the race tracks for MX. Probably put 200-300 miles every weekend on my Ecoboost towing. The truck pulls it so easy its disturbing. It doesnt even know its back there. A lot of people say that about there trucks, and i would have said that about my 99 F-150 last year when i used it to tow the same rig.
My ecoboost out does my 99 5.4l in every way imaginable.
The dealer is sneaky. One of them called my house and said I should come into the dealership and talk to their "truck guy". Well after telling the truck guy I wanted max tow and max payload he tried to talk me into buying another truck he had on the lot, but didn't have the max payload. That's why I started doing some research. My gut says to get an f350 for this kind of work, but I don't have the money to go big and get the diesel, and if this turbocharged v6 can tow 10,000 pounds then it's up for the job.
you will very likely have to order one to get the max payload option, most have.
truth be told, you are right on the bubble between a super duty and a half ton. the lines between the two have been effectively blurred. i don't think you can go wrong either way, to be honest.
max tow may get you there, but some have found it hard to stay under GVWR with the trailer and a family. the max payload adds a margin of safety in that regard.
a dealer trade might get you one with the max payload. i'm pretty sure woodhouse in nebraska would have one on the lot, just have to work out a dealer swap if they do.
before pulling the trigger, you should ask tom about his new setup.
he is very conscientious about vehicle loading. his new rig is exactly what you are talking about and he went home with a new max tow without the max payload.
I've got a very similar set-up to Tom's except mine is an FX4 vice an XLT...max tow/no max payload. My max tow capacity is 11,200 lbs with 1,580 lbs of payload. GCWR is 17,800 or so. I routinely tow 9,000 to 10,000 lbs with a tongue weight of 980 lbs using a good weight distributing hitch. Drivetrain-wise the truck handles the load just fine. Towing fuel economy isn't great...between 8-10 mpg depending on conditions...but I'll sacrifice a little bit of economy for a more friendly truck when not towing. Although the ride and suspension was acceptable towing that load, I thought it could be better. I swapped out the P-rated stock tires for LT rated tires with stiffer sidewalls, and added the Firestone air bag system in the rear. For a lot less money than a Super Duty, the changes really enhanced the experience of using the truck at it's full capacity. Aired up to about 50 psi in the bags it's steady as a rock with no sway or porpoising.
Thanks Mike! Unfortunately I want to get this thing broken in before stressing it out too much, so I have another ~800 miles before I put this thing to the test. I plan on loading my 7,350 lb Excursion in my trailer(4,550 lbs) at that point to see how it does. With equal torque and more horsepower than my V10 I have high hopes!
What exactly are you towing? Depending on configuration 8-10 isn't bad at all. My 2011 F350 had the 6.7L Powerstroke diesel and I only got ~10 MPGs towing my white trailer at 65 MPH.
I could have gotten a 6.2L F350 for around the same price, but I went with the half ton because of how frequently I don't tow. I only pull any serious weight a few times a year, and the F150 is a MUCH better driving truck in just about every situation. Since trading my last F150 I've had an '08 F250, '11 F350, and my '00 Excursion. I vastly prefer the way the F150 drives to all of them, and I don't have the diesel maintenance headaches or potential $20,000 repair bill out of warranty.
I don't think you'd do much better with a diesel truck. Perhaps 10-12 if you're easy on it. I really liked my Powerstroke trucks, but cheap to operate they aren't. I tend to think the better fuel economy is offset by the increased price per gallon, extra maintenance, and repair costs when they break. Wonderful for those who consistently tow, but just not worth it for me.
I bought this truck and have never looked back. Spent and additional $1,800 on the tires and air bag system, and have all the capability I need. A similarly equipped Super Duty diesel would have been about $13K more. I can't recommend the Ecoboost F150 enough.
My only concern is the relatively light axles for my use. Here's my last weight ticket:
I was helping someone move, and she loaded it to the gills. I don't plan on running that heavy again; I had about 2,000 lbs on the tongue. Far exceeded the capacity of the hitch, but I was under the rated capacity of all my axles. The photo above was with this load; with my Air Lift airbags it almost looks normal!
Wow....that's a lot of weight. Any idea how far over you were on the tongue? Agree that's way beyond what you'd want to try with the F150. I think you're right though....especially with the Ecoboost the drivetrain wouldn't be the limiting factor.
I'm just guessing because I don't know the actual weight of the stuff in the truck. I'm guessing around 700 lbs, and my Excursion with a full tank is 7,350 lbs. So 10,040 - 700 lbs - 7350 = 1,990 lbs. The hitch on the Excursion is rated for 10,000/1,000, so I was WAY over on tongue weight. Long story short, I couldn't find a scale until I was 2/3rds of the way there, and I figured I didn't rip the hitch off at that point so I was good. Definitely had me nervous though, and I'll be purchasing a portable tongue weight scale next time I load up with anything but a car.
The hitch on the new F150 is rated at 11,500/1,150, but it doesn't appear as overbuilt as the one on the X. I can only hope it would handle that much weight as well, but I sure as heck never plan on finding out!
