Fender support
Old Apr 9, 2013 | 09:03 PM
davewave649's Avatar
davewave649
Fender support
So I managed to chase down a squeak in my passenger side fender but I have no clue how to fix it. The problem seems to be that the C-channel looking support that holds the J-nuts where the fender meets the cab is separating from the fender skin. How do I fix this? I'd rather not have to weld and mess up the paint but I guess that would be better than the fender coming off
Old Apr 9, 2013 | 09:55 PM
schoo's Avatar
schoo
Just looked at mine there off the truck is it the one where the bolt goes thru the side of cab if so it's about 3 to 4" from the corner and I bet u could weld if the metal is not torn to far
Just remembered their is a rubber spacer between fender and cab at that corner
Old Apr 10, 2013 | 01:18 AM
Buzz44's Avatar
Buzz44
If the metal is torn or cracked remember to stop drill first then weld.
Old Apr 10, 2013 | 01:38 AM
davewave649
Thats the thing im not seeing any tears but i will pull the fender next time im in ventura and see
Old Apr 10, 2013 | 10:53 AM
Buzz44's Avatar
Buzz44
Maybe just some spot welds broken loose.
Old Apr 10, 2013 | 02:10 PM
davewave649
Thats what im hoping for, I could pull the fender this weekend and look but I dont have anything here at school to fix it so im probably just gonna wait a week or two till im home again to check it out
Old Apr 19, 2013 | 12:17 PM
davewave649
Didnt find any broken welds but i spot welded the support in place because it was loose. even managed to not have to ruin the paint
Old Apr 19, 2013 | 01:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1961/63 is the same.
Old Apr 19, 2013 | 07:20 PM
davewave649
Thanks for the info Bill, spot welding rib in place seems to have stopped the rattling/squeaking.
glassmanbruce
Jan 9, 2016 09:30 AM
jrockdiddy
20
Apr 27, 2014 05:57 PM
tip49
Jun 17, 2010 12:34 PM
edillen
2004 - 2008 F150
Jul 27, 2005 04:40 PM
timjen
Jul 30, 2004 01:28 PM
