How fast do tow?
Old Apr 8, 2013 | 10:57 PM
Sunline Fan's Avatar
Sunline Fan
Excursion Fleet Manager
60-65 here, occasionally get up to 68. I like to keep it around 65 though because the closer I get to 60 or below, it wants to downshift. It pulls nicely at 65.
Old Apr 8, 2013 | 11:02 PM
Skip1970's Avatar
Skip1970
At 12k i just do the 55mph or so , with a empty trailer or small 5k or less reailer 60-65mph
Old Apr 8, 2013 | 11:17 PM
Truck Guy99's Avatar
Truck Guy99
I have towed many a thing, but like everyone else is saying it all depends greatly on conditions, terrain, etc. I do my best to stay at 60-65. But if you have a steep hill, a pickup, a big gooseneck, a tractor with a brush hog, and some fear, that aint always possible to stay at. Ask any trucker with some descent miles behind the wheel. Even empty, you sometimes do what you have to to stay up. Example: empty pickup, long 3 or 4 percent grade, 3 fat boys riding in the cab, a toolbox with at least 3 or 400 pounds in tools, and nearly bald tires. Hit the bottom of the hill foot to the floor, topped it between 50 and 60. Didn't cut it as close as we thought we would, but still a little scary watching your foot on the floor and seeing the speedo starting to dive.
Old Apr 8, 2013 | 11:24 PM
Pickupmanx2's Avatar
Pickupmanx2
Veteran: Marine Corps
What evah do yo mean?!!?
Yup,,, done a few dumb things, lived to tell about them, don't plan on repeating them! But as you so eloquently stated, sometimes ya do what ya gotta do!
Old Apr 8, 2013 | 11:36 PM
Truck Guy99
Testify! You gotta admit, even empty a truck can struggle if the grade or terrain is bad enough. Even a 4x4 can get stuck if the mud conditions are bad enough. That's all I got to say about that.
Old Apr 9, 2013 | 01:01 AM
CLINT-THE-GREAT's Avatar
CLINT-THE-GREAT
Posting Legend
The few times I have towed since I have bought my Ex, usually 63-67 mph with a 14' 5,000 lbs tandem trailer. No problem with sway. Did blow a turbo boot off tho
-The Great
Old Apr 9, 2013 | 01:54 AM
Stebs's Avatar
Stebs
I'm in the "as conditions will allow" category... Im also **** about tire pressures, properly secured loads, AND BRAKES! I had probably 15k behind the ex one day and discovered that the trailer brakes were too far worn to be worth a flip at that weight, ended up doing 25-30ish in a 55. Luckily I only had to pull that maybe 10 miles and only on paved backroads that are hardly traveled.
What really scares me is the people that hook up to trailers and have no clue about weight or brakes, or properly loading. For instance, my dad thought his Dakota could pull the 20' tandem axle flatbed with no trailer brake controller, on the interstate at 75 and still get his usual 17ish mpg. I damn near fell out of the ex laughing!
Old Apr 9, 2013 | 06:20 AM
Tom's Avatar
Tom
Originally Posted by az_r2d1
Whoa that's a big sucker.
What are you going to do once the EX is sold ?
No way that f150 can handle that.
It actually can. I towed my white trailer with my '07 F150, and we had it over 9,500 lbs a couple of times:
The new one, assuming the deal goes through okay, is rated to tow 11,300 lbs. It has as much torque as my V10, 55 more horsepower, a longer wheelbase, and a fully controllable 6-speed transmission.
Old Apr 9, 2013 | 11:14 AM
az_r2d1's Avatar
az_r2d1
serious? What's the weight of that f150 ? which engine ?
edit:I just looked it up.. less than 5000 lbs truck weight. Somehow that seems like a bad idea to tow 11,300 lbs.
It is with the ecoboost and heavy duty towing package.
That ecoboost does seem like a great engine. Was watching a show where they used a tuner to add some hp and did exhaust work. Just the tuner alone added 100 hp I think.
Old Apr 9, 2013 | 11:28 AM
Tom's Avatar
Tom
You must have looked up the wrong one, base curb weight is 5,687 assuming no options and GVWR is 7,650 lbs. My Excursion has a curb weight of 7,350 lbs.
Old Apr 9, 2013 | 11:40 AM
az_r2d1's Avatar
az_r2d1
yep, I stand corrected. They've come a long way with these trucks.
Old Apr 9, 2013 | 12:36 PM
Skip1970's Avatar
Skip1970
I took put ex thru the scales full of fuel it was 9400lbs
Old Apr 9, 2013 | 01:11 PM
  #28
william_04_x's Avatar
william_04_x
Wow, that truck is heavy! Does it have an extra layer of fat to keep it warm up there?
Old Apr 9, 2013 | 01:21 PM
  #29
Archion's Avatar
Archion
How many people and how much gear?
Old Apr 9, 2013 | 01:32 PM
  #30
rlt7272's Avatar
rlt7272
I keep all my trailers between 55 and 65 and stop every couple of hours to check hubs and load. The one time I opened the dodge up pulling my 33' travel trailer I was coming thru the Texas panhandle at 80 and popped a tire on the trailer. Thousands (and I do mean thousands) of miles pulling that same trailer at 55-65 the tires were fine. I took that as an omen and slowed back down.
Just because our trucks can do it doesn't mean they should. Same goes for unloaded speeds.
