Belltech drop springs?
Old Apr 8, 2013 | 11:45 AM
EffunFiddy's Avatar
EffunFiddy
I've searched the forum for info on these springs but wasn't able to find anything on these particular ones, just cutting springs. From what I've read about alignment with drops I may already know the answer, but not positive.
Belltech lists 2 inch drop springs (#4800) for '87-'96 F150, mine is an '85. Moog lists replacements for '85 and '87 as the same number, and Belltech can't tell me if there is a reason that their springs aren't listed for '85.
Lastly, at 2 inches are they going to make alignment impossible? I understand they are difficult to align in stock form, but figured if they made them for these trucks there must be some reason. I really didn't want to go with the drop I beams simply because of the cost, but if the springs are going to be a nightmare I would sooner do it right the first time. Thanks in advance
Old Apr 8, 2013 | 12:01 PM
Social_Joe's Avatar
Social_Joe
The springs on my '83 1/2 ton were so worn that when I replaced them with Moog Replacements it RAISED the truck nearly two inches. I'd imagine with a 2" drop spring, you'd need to get different camber adjusters for the upper ball-joints to correct for the negative camber you'll encounter. The adjusters on my 2WD are non-eccentric, meaning they don't actually adjust anything when you turn them, so you'd need ones that have an off-centered hole (eccentric) to allow you to adjust camber.
Old Apr 8, 2013 | 12:09 PM
EffunFiddy's Avatar
EffunFiddy
Thanks for the quick reply. I'll look into these adjusters to see where I can get them.
Old Apr 8, 2013 | 12:12 PM
Social_Joe's Avatar
Social_Joe
I don't know this for fact, but since the 4x 1/2 ton trucks and 2x 3/4 tons sat taller, they MIGHT have eccentric adjusters to correct for the positive camber of the taller springs. Also, I'm sure they're easily available, TTB Fords have had camber issues since the first set of springs installed on one got worn down.
Old Apr 8, 2013 | 12:21 PM
EffunFiddy's Avatar
EffunFiddy
Right on! I'll see what I can dig up. Looking into what you were saying and Moog lists a variety of different ones. Thanks!
Whitey5.0
Nov 7, 2017 11:19 AM
Blue 55
Jul 3, 2015 11:25 AM
93beast
15
Jul 20, 2012 09:16 AM
71fordkid
Oct 12, 2007 09:44 AM
I_Thnk_Ford
Feb 28, 2005 05:03 PM
