heated springs
Old Jul 17, 2012 | 07:50 PM
93beast's Avatar
93beast
heated springs
Ok sorry if there is a thread already but i get on here with my phone anyone ever heated there springs i have four kids and funds are not even in the picture lol so i beams are out just scared the steering shaft will get in the way any help would be much apreciated and i dont care bout ride quality so keep it to your self
Old Jul 18, 2012 | 11:39 AM
ChaseTruck754's Avatar
ChaseTruck754
Heated springs will typically tend to continue to sag.
Also keep camber in mind if you do this. Camber on these trucks isn't adjustable really as you have to bend the i-beam itself to correct the camber. So if you drop it by heating the springs your camber will be off and you'll eat tires = $$$
Old Jul 18, 2012 | 09:45 PM
hasteranger's Avatar
hasteranger
once you heat spring steel enough to sag it, its not spring steel anymore, generally speaking.
Old Jul 18, 2012 | 10:01 PM
93beast's Avatar
93beast
Lol what does that mean and i wish i could see a pic of one where the springs hsve been cut or heated
Old Jul 18, 2012 | 10:21 PM
HIO Silver's Avatar
HIO Silver
Generally speaking, spring steel's metallurgical properties has strong molecular bonds and maintains the shape and properties of when it was drawn. Heat it up too much and the molecular structure changes thus losing its ability to rebound.
Carbon steel's structure is comparatively weak so you can bend it to a new shape. Note that it heats up when ya bend it because energy (the molecular bonds) are being broken.
Attempt this... use a hacksaw and try to cut a coil off a spring.. you'll go through quite a few blades and work up a good sweat.
Using a grinder and cut-off wheel (or metal chop saw) isolates the built-up heat to a small area... And NEVER use an acetyline torch to cut springs.
Old Jul 18, 2012 | 10:24 PM
93beast's Avatar
93beast
Yeah i cut the springs on a foxbody just heating them will be easier
Old Jul 19, 2012 | 12:07 AM
HIO Silver's Avatar
HIO Silver
Thumbs down
Enjoy your ride quality...... or what is left of it.
Old Jul 19, 2012 | 05:45 AM
93beast's Avatar
93beast
It really aint that bad
Old Jul 19, 2012 | 05:55 AM
Canus's Avatar
Canus
As HIO Silver said, when you heat spring steel which has been put through a specific heat treatment by the manufacturer you alter that heat treatment. Heating springs to any temperature above approximately 400 degrees Fahrenheit will alter the original heat treatment and the spring will no longer perform as designed. Not only will ride quality suffer (which you don't seem to care about) the vehicle can easily become unsafe. You may not care about your life but think about the other folks on the road. Just my 2 cents worth.
Old Jul 19, 2012 | 11:04 AM
ChaseTruck754
I'd agree that cutting a coil (if done properly) is better than heating them for all the reasons mentioned above.
IF you cut the coils - do it with a cut off wheel on an angle grinder, or better yet - a port-a-band (small bandsaw) if you have one.
Old Jul 19, 2012 | 11:23 AM
hasteranger
Or just let your truck sit for 6 years then fire it up and beat the crap out of it. I had a full turn rusted/broke off the bottom of each of my front coils when I removed them. lol
Old Jul 19, 2012 | 11:24 AM
ChaseTruck754
that method seems to be location specific though!
Old Jul 19, 2012 | 11:30 AM
93beast's Avatar
93beast
Lol she wont be sitting anytime soon thanks for the advice guys
Old Jul 20, 2012 | 01:29 AM
bamaf150's Avatar
bamaf150
You must have missed the memo about "keepin it to yourself"
Old Jul 20, 2012 | 07:23 AM
jim collins's Avatar
jim collins
---Dumb,dumb idea,--thats the way we lowered our cars 50,60 years ago. It always screwed up the front suspension ,speaking from experience ,I'v done my share of them. The springs,coil or leaf can break with out a warning after heating and cooling ,causing the vehical to get out of control. Oh well ,at least you are not in my state so i'm safe.---
