Fuel Gauge 97 F53 Flair
Three years ago while on the road the fuel gauge dropped from full to nearly empty over a few minutes. No fuel leaks, engine kept running fine. The opinion of most people was a bad float or sending unit. Lived with problem till a week ago and replaced entire assembly in tank with an OEM replacement. Same reading on gauge. Found a video on youtube about a Taurus with similar problems. Owner insulate three left contact and shorted two right contacts on anti slosh module. Plugged module in & dash guage worked, though it was erratic if the car was rocked. I did this on my module with similar results. Reading is more stable, 75 gallon tank may help. Bought a used replacement module, same almost empty reading. Now the question. Can these modules be tested and repaired? Can't find a new one.
Thanks,
Mike
Thanks,
Mike
Not sure how you would go about testing it unless you stuck it in another cluster.
You could try replacing the chip and the cap I guess. I do not see much on the board that could go bad.
Here is a source for the board from a June 2008 posting:
fuel gage anti slosh module
Hi All
I am getting a few calls about that infamous module for the fuel gage on the 90-95mustang.
The part number is E9SZ-10E849-A and has a list price (today) of $85.32 and a FFCARS cost of $63.99 plus shipping. I titled this post so a search would help find it fast. I normally stock this part.
Max Zuckerberg
Parts Specialist
Five Star Ford
7100 east Mc Dowell Road
Scottsdale AZ 85257
Direct 1-800-866-1520 ext 236
Fax 1-480-949-8478
parts@fivestarford.com/
Hi All
Max Zuckerberg
Parts Specialist
Five Star Ford
Scottsdale AZ 85257
Fax 1-480-949-8478
phelios27
11-09-2007 06:20 PM
