Winch is cool, may have to rethink that bumper a bit. The emblem, I do not know on the first years if Ford did the V8 emble, maybe someone will chime in on that infromation.
Gear and lightning bolt use up until 65. V8 used on 65 and 66. When I got my 63 4wd the front bumper was moved forward and you can see where the front frame crossmember was nothched and the trans frame crossmember was notched. My guess is that it originaly had a winch on it.
Thanks BUZZ, I should know that, but I have only owned 65 and newer thucks.
