1966 - 1977 Early Broncos
Help!! Numbers Dummy
Old Apr 7, 2013 | 01:21 PM
alan ogden's Avatar
alan ogden
Local Parts suppliers have ''Not a Clue",68' EB Vin# U15NLCOL 1281
del.,Sept.,67' sac.ca. 289/302? (3) blts on bal.(5) on bel.Cast#s block
D10E-8015-AA,oil pan #D1TE-6675-BA ,Trans.tag#D3TA 7008 DC FL 112,Cast #
C 96391-S,below that 5928, 4spd.W/ Cast iron shifter housing.
Front dif.#354 D6 TA AJD , Also 6037 80 3
Rear dif.# 3L50 7HB 695 ,2.5 X10 Brakes
That is all i have. " Stock or Not that is the question " !!!
Old Apr 11, 2013 | 10:51 AM
Nightstick180's Avatar
Nightstick180
Assuming you want to know whether or not what's on your bronco is factory or not? For the 68, it should be a 289, but your casting code "D10E..." indicates it's a 70s motor. The D is 70s, E is 80s, etc.
The tranny is most easily identified by sight. If you go the tech article section on classicbroncos.com and go any of the transmission articles they have pics of them all. Chances are if it's an auto it's a C4 or if it's a manual it's probably a RAT/RAN. RAT/RANs are factory 3spd + reverse. If it's a 4spd + reverse you might have an NP435. Again, pics are the easiest way to tell.
Front axle from the factory would be a Dana 30. Starting in 71 or 72 they went to a Dana 44. The way to tell the difference is the Dana 30 has a kingpin knuckle as opposed to ball joints.
If you post a pic of your tranny via photobucket I can tell you what it is.
Old Apr 14, 2013 | 10:43 AM
alan ogden's Avatar
alan ogden
Help numbers Dummy
Nightstick 180 Thanks for reply:: Yes i would like to - know what came "stock" on my 68'. I guess the Engine is 80's? year t Vin# says = "289" Started looking for a 67'-68' stock 289{ complete} not much luck.. Found a picture of trans. NP 435 great ! Rear Dif. has "44" cast on housing, Dumb Question, are 44's & "9'' Different all together ? if so should i start looking for a "9" THANKS Alan
Old Apr 14, 2013 | 01:28 PM
Nightstick180
It would be highly unlikely you have a D44 rear. Those never came on broncos. If someone switched it out they're retarded. Easiest way to tell the difference between a 44 and a 9" is the 9" has a third member, 44 does not. Meaning, the 9" bolts will be on the driveshaft side of the axle. If you take off the nuts and pull the axles out, you can remove the entire diff. The 44 bolts are on the opposite side of the driveshaft and if you remove them the cover comes off to reveal the diff but it doesn't come out as an assembly.
NP435 is a great bulletproof tranny. Doesn't do you any good for a street rig, but they're great for crawling.
If you're trying to go back to a stock configuration the 289 is what you need. No point in doing so if you're not though.
Old Apr 25, 2013 | 10:27 PM
hotrod351's Avatar
hotrod351
easy, dana 44 has a bolt on cover like the front dana 30. looks just like it only bigger.
nlareau
Aug 2, 2011 08:45 PM
1980ford4x4
Jul 24, 2010 07:56 PM
Customcab
Sep 30, 2007 01:03 PM
74ExplorerHalfcab
15
May 2, 2004 11:38 PM
