speedometer gear
Old Apr 7, 2013 | 11:47 AM
85grey's Avatar
85grey
speedometer gear
On my 88 250 the gear that is inside the transfer case on the zf5 on the output shaft is wore out. My gear is yellow. I purchased a new gear and put it in. What I can't figure out is what holds it from sliding down the shaft away from the gear on the end of the speedometer cable. It will ride in place for about five miles and then slide far enough down the output shaft on the transfercase shaft. Then the two gears don't have connection and the speedometer doesn't read. I have tried turning the gear over, thinking maybe the threading might hold it on the shaft but no luck. Any ideas?
Old Apr 7, 2013 | 05:38 PM
tjc transport's Avatar
tjc transport
i ain't rite
there is a small "C" clip that holds the gear in position on the end of the cable.
Old Apr 7, 2013 | 07:15 PM
85grey's Avatar
85grey
Tom, you are talking about the gear on the end of the cable
I am replacing the gear ON the shaft inside the transfer case that turns the gear that you are referencing.
Old Apr 7, 2013 | 07:32 PM
tjc transport
i ain't rite
sorry, never got that far into one to get to that gear.
i thought you meant the cable gear.
Old Apr 7, 2013 | 07:40 PM
85grey's Avatar
85grey
no problem
Old Apr 8, 2013 | 07:13 PM
85grey's Avatar
85grey
Anybody done this before?
Old May 6, 2013 | 06:25 AM
85grey's Avatar
85grey
I ended up putting J B Weld on the gear and that seems to be holding it on the shaft
264WSM
Jul 18, 2015 04:23 PM
Mystery Inc
Nov 1, 2013 06:07 PM
kona56
Apr 5, 2010 02:13 PM
Walker1940
Jun 5, 2006 07:17 PM
Southern Fried
Feb 7, 2002 03:35 PM
