Choosing correct power valve
Old Apr 11, 2013 | 08:07 PM
Franklin2's Avatar
Franklin2
Once you really get into carbs, it's when you realize the aftermarket carb people are really sticking their neck out, they have no idea what their carb is going to be installed on. So you can be pretty much guaranteed the aftermarket carb you are using is a compromise to fit most engines.
It also brings to realization that the factory spent a lot of time tuning and calibrating their carbs to each specfic engine setup, and when you start messing with anything, even the exhaust system, you are messing up the calibration of the carb.
Old Apr 11, 2013 | 10:49 PM
Gary Lewis's Avatar
Gary Lewis
Luckily the naturally-aspirated gasoline engine has a pretty consistent A/F requirement regardless of brand. And, it is very tolerant of variations in the ratio - as long as you aren't requiring its exhaust to be squeaky clean. Or, if you aren't looking for the last MPG or HP. Yep, carbs are a compromise.
Old Apr 14, 2013 | 06:19 AM
Ken Blythen's Avatar
Ken Blythen
One more query.............
The 2150 that I'm re-kitting has emulsion tubes with 8 holes each near the top.
I have a spare parts carb (also a 1.21, 2150 but the tag is missing) that has rows of vertical holes down the length of the tubes, & I've heard this was the better design - is that correct?
If so, will the whole booster assembly swap satisfactorily, or am I better to stay with the original parts?
Old Apr 14, 2013 | 08:39 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Ken, from my experience with Weber, Zenith and Solex carbs, the larger number of holes in the emulsion tubes aids in throttle response and will actually make it run richer.
Specific example, 1972 Mercedes-Benz 250C (2.8L SOHC with dual Zenith 35-40 INAT progressive 2bbls.) The primary emulsion tubes had 2 holes mid-way up. I found a set of Weber emulsion tubes from a bunch of scrap Pinto Holley-Webers with maybe 10 holes in them, the main jets had to go down 3 or 4 sizes it ran so rich.
Franklin2's Avatar
Franklin2
I would compare jet sizes and all the other little air bleed hole sizes. The different design may require a difference in some other part of the carb, you never know. But that piece is easily changed if you wanted to experiment correct?
Old Apr 14, 2013 | 08:48 AM
Gary Lewis's Avatar
Gary Lewis
I agree - check all the various bleeds and restrictions. I don't know about the 2150's, but many carbs have restrictions built into the passages which limit the amount of air or fuel flow regardless of the bleed or jet size. I've seen instances where a main jet or PV change gained nothing due to a restriction.
Old Apr 15, 2013 | 06:00 AM
Ken Blythen
OK, thanks all.......I'll leave everything as original for now. Yes, it can be swapped easily later, Dave.
I'm optimistic that this carb is going to be good - it's not butchered up, has almost no throttle shaft or other wear, is still tagged, & is surprisingly a full match for the year & engine of my truck.
It was thrown behind the seat of a parts truck I bought.....the PO said it was 'just a piece of junk', but he had tried to run it with the jets missing & given up in disgust.
You've gotta be lucky sometimes
Old Apr 15, 2013 | 07:58 AM
Gary Lewis's Avatar
Gary Lewis
Wow! Running a carb w/o jets has got to be ..... interesting. It should idle, but would probably bog down very quickly if you cracked the throttle. Bill - Surely one of your guys tried that? (Not you, I'm sure.)
Old Apr 15, 2013 | 11:56 AM
85lebaront2
No, but a member on here (you should recall the thread) ended up finding his Qjet problem was a bent primary metering rod, similar effect, pig rich.
Old Apr 15, 2013 | 12:40 PM
Gary Lewis's Avatar
Gary Lewis
I do remember. A wide open jet would be RICH. And it would probably have kept the other side in power mode as well.
AbandonedBronco
38
Jul 7, 2024 03:10 PM
danlee
Sep 9, 2011 02:08 PM
LARIAT 85
Nov 6, 2010 04:08 PM
Arno F100
Nov 29, 2008 05:36 PM
mgoovaerts
Dec 29, 2003 08:24 AM
