Modular V10 (6.8l)
V10 wont start
Old 04-06-2013, 09:19 PM
travishy's Avatar
travishy
travishy is offline
V10 wont start
I have a 2002 f350 v10, the other day I replaced the pcm relay and when I went to start my truck the engine turned for a second and then the fuse panel fried, so I replaced the fuse panel but the starter will not turn when I turn the key, when I get under the truck and jump the starter it will turn. Everything else works radio, windshield wipers etc., do yall think the pcm or the starter solenoid or the ignition switch on the steering column also get toasted when the fuse panel went. I was gonna check some voltage tomorrow hopefully. Thanks.
Old 04-07-2013, 01:48 PM
travishy's Avatar
travishy
travishy is offline
anyone have the ignition wiring diagram for 02 f350 v10
Old 04-14-2013, 12:45 PM
travishy's Avatar
travishy
travishy is offline
Update: I replaced the fuse panel with one from a junk yard and also replaced the ignition switch under the steering column. I am getting power out of the ignition switch and through the relay on the fuse panel but not to the starter. I can get under the truck and start it by jumping the starter, starts fine this way. I have tried to start in park and neutral makes no difference. I still cannot find a wiring diagram for this year model, any help on this would be greatly appreciated the Haynes manuals have diagrams but not for an 02 model and they do not have the same wiring as a 99 to 01
JAM7.3L
03-06-2016 05:37 PM
Charlie Doc
Modular V10 (6.8l)
06-12-2014 04:08 PM
burnermaker
10-11-2007 06:12 PM
kaptar
2004 - 2008 F150
07-26-2007 12:08 PM
Quick Reply: V10 wont start
