Sponsored by: Real Truck
rear problem
Old Apr 6, 2013 | 06:10 PM
jcburns420's Avatar
jcburns420
rear problem
I not I ex the smell of gear oil and my back tire smoking I replaced the Axel seal but I'm still having the same problem any ideas?
Old Apr 6, 2013 | 09:30 PM
AzPete's Avatar
AzPete
Gear oil on brakes from original leak?
Old Apr 6, 2013 | 09:52 PM
Bigpipes 35's Avatar
Bigpipes 35
Make sure your axle vent is not plugged, If it is that will cause the issues you are having because as the axle gets hot it builds up pressure and if the vent is plugged the pressure has to go somewhere and its usually out one of the seals...
Old Apr 6, 2013 | 10:13 PM
EXv10's Avatar
EXv10
Sure it's axle oil?
Old Apr 7, 2013 | 01:58 PM
Lou Braun's Avatar
Lou Braun
The back wheel smoking could well be caused by a dragging brake. Check to see if the rear rotor gets hot while driving. Rusted caliper pins or a frozen caliper could result in overheated brakes.
Severely overheated brakes may have caused the axle seal leak.
Lou Braun
davisjam
6.7L Power Stroke Diesel
Mar 4, 2018 11:29 PM
79F150400M
Apr 10, 2012 10:36 PM
biggreen78
Sep 23, 2008 11:34 PM
imlowr2
20
Oct 13, 2007 11:03 AM
maxbm
Modular V10 (6.8l)
29
Jan 22, 2006 08:10 AM
