POWER STEERING ISSUES
Old Apr 6, 2013 | 02:28 PM
cheezit's Avatar
cheezit
there is a screen in the bottom of the resivior that plugs with trash and causes a reduced flow.
my guess is a bad reman gearbox... take it for what its worth im not now nor have i ever been a front end / suspension guy
Old Apr 6, 2013 | 02:36 PM
HENRYTHETOWMAN's Avatar
HENRYTHETOWMAN
I bought the gearbox from a local ford dealer, is it possibly defective? They told me at the dealer that it was new, not reman, it cost me $1600, crazy right? I went ahead and replaced it cause it had alot of play. I felt like it was time to replace either way
Old Apr 6, 2013 | 03:50 PM
Snuggyworm's Avatar
Snuggyworm
Have u tried to bleed the hydro boost a little yet? If tat releases pressure, them I may have found the root cause of ur prob, and then all u need to do is do a power steering fluid flush.
Old Apr 6, 2013 | 08:06 PM
HENRYTHETOWMAN
How do i bleed the hydro pump, do i just disconnect one of the hoses? Sorry this is my first hydro boost problem!
Old Apr 6, 2013 | 08:18 PM
BLADE35's Avatar
BLADE35
The Hydro pump will self Bleed air out
All you do is turn the Steering Stop to Stop and Pump the Brakes the Air will come out in the reservoir just cycles the system
Id pull the return line off and see if it has Flow
you can plug/cap return hose and run temp line and let it drain into reservoir basicaly so you could see it
Now Iv never seen anything but makes me wonder if a guy could hook a Pressure gauge up to check condition of the pump
Old Apr 6, 2013 | 08:38 PM
HENRYTHETOWMAN
Thanks alot, ill work on it all day tom, hopefully ill have some good news!!!
Old Apr 6, 2013 | 10:13 PM
Snuggyworm's Avatar
Snuggyworm
Good luck sir! Let us know how it goes.
Old Apr 13, 2013 | 01:26 AM
Master Technician's Avatar
Master Technician
Thumbs up
i,m working on a 2007 ford f450 with the same problem,(brakes and power steering issues,i put a new power steering pump on it and cleaned out the cooler and lines,AND ITS FIXED, CHANGE YOUR PUMP!! you do have 2 pumps that work together 1st is the power steering pump that is belt driven,2nd one is mounted on your firewall right behind your master cylinder.hope this helps
Old Apr 13, 2013 | 07:24 PM
cheezit's Avatar
cheezit
the "second one" is not a pump. its a hydroboost unit. it just replaces the vacuum booster that you would find in a car
Old Apr 13, 2013 | 09:41 PM
daddykitty's Avatar
daddykitty
that is the accumulater
53fatfndr
Sep 25, 2022 11:47 AM
cps
Jun 21, 2018 09:35 PM
jmuenchow
Jun 24, 2017 11:22 PM
