When it first came out, I think Amsoil was probably the best, but there have been such advancements in the synthetic oils over the years, that the difference is probably negligible now. I have no evidence to prove this, I just think there are several good oils out there, and I dont see how Amsoil can be that much better. I have run a used oil analysis on 8k mile Rotella T6 and it came back fine. That was with the Ford filter, I now run the Mobil 1 filter designed for extended drain intervals.
My problem is that I haven't been running synthetic just regular old rotella.....I'm at 208k now need to make truck last
No reason to not start running T-6...That is the reason I asked about location...if you get colder temps in the winter T-6 is perfect for you. Heck, T-6 is about right for anywhere.
I live in east Tennessee our cold most of the winter is freezing or a little lower. Not to extreme....will the Donaldson BHOF fit my early 99 with out making changes? How much extra oil does it hold? I
I run Delo 400LE 5w-40 synth now and will run T6 on occasion, both at 7.5K intervals. Was running motorcraft 15w-40 dino at 5K intervals. Sounds like both intervals are conservative enough with todays quality oils. Using the motorcraft filter.
I like the quieter operation of synthetic, combined with the hutch/harpoon, suction side fuel line replace/pre-filter and FRx mods. Very smooth quiet (for a 7.3) operation in stock tune.
That is not a problem, totally OK. Just keep doing what you have been doing and you should have several hundred thousand miles to go before you begin to worry about engine wear.
Originally Posted by awillo0406
How long would you run rotella T6 before changing it??
Not sure. I usually go about 7-10k miles between changes on regular Rotella T or Motorcraft or Delo etc. If your truck doesn't see regular use then T6 (or something similar) might not be a bad idea. Even then, I'd change the oil once a year at a minimum. I change the oil on my truck about every four months so regular Rotella T does just fine.
The T-6 is perfect for you then...you will love it on the cold morning starts! You don't need any special oil filters, the Motorcraft would be more than adequate for your one-year/7K change interval. The Donaldson BHOF (Big Honkin' Oil Filter) will go on without modification, I believe.
