Hey everyone, I'm new here and have a few questions about a three speed transmission I'm rebuilding for a buddy. The transmission is in a 1964 f100 223 SWB but it isn't the original.
Upon tear down I found the cluster gear, reverse idler, sliding gear all have chips in them so I figured we might as well replace all the gears and do a complete overhaul.
So far this is what I have found to be in the transmission:
I am hoping someone might be able to fill in the blanks and point me in the right direction for NOS parts. Thanks in advance for all the help.
1953/62 F100's came standard equipment with Ford 3 speed manual non syncro 1st gear.
1M26: This trans assembled December (M) 26, 1961 (1). Parts listed above are for 1960/62 F100.
7106 only furnished with syncro assy, but the 3 syncro shoes (C3AZ-7A044-A) and 2 blocker rings (C3AZ-7107-C) also sold by themselves. See pic in post 16.
B6AZ-7B331-A .. Small Parts Kit includes all the snap rings & washers / C0TZ-7153-B .. Gasket Set.
1963/83 F100's came standard equipment with Ford type 3.03 3 speed manual all syncromesh transmission.
Call Green Sales Co. in Cincinnati OH = 800-543-4959, they should have most/all of the parts.
The front/rear bearings have BIN's (Bearing Industry Numbers) stamped on them, what autoparts stores, bearing shops go by.
Note: Part number prefixes that the 2nd digit is a zero can also be typed as the letter O.
I've sourced most of the parts through Green and wesleys obsolete there is one part I'm having an issue finding in NOS and that is the mainshaft B5C-7061-A.
As for the synchro sleeve the best I could find was 01A-7106-A not quite sure on the compatibility.
Ford 3 speed non syncro 1st gear: 7106 only furnished with the 2/3 synchronizer assembly: C2TZ-7124-A =
FREESE MOTORS in Monticello IA has ONE = 319-465-3541.
CROSSETT FORD in Crossett AR has ONE = 870-364-2162.
CARPENTER NOSOBSOLETE PARTS in Concord NC has TWO = 800-476-9653.
WESLEY OBSOLETE PARTS in Liberty KY has THREE = 606-787-5293.
----------------------------------------------------------------------------- B5C-7061-A =
AITKEN MOTOR CO. in Aitken MN has ONE = 218-927-2169.
BEN DAVIS FORD in Auburn IN has ONE = 260-925-3100.
Bill IS " The Man" " ( Mon.-Fri., 9a.m-5p.m., at any rate) What he is or does afterhours , I dunno and I don't care. What happens in Hacienda Heights stays in Hacienda Heights!
