NO spark NIGHTMARE
Old Apr 3, 2013 | 09:12 PM
9d4's Avatar
9d4
NO spark NIGHTMARE
OK...my 73 f 100 4x4 has the no spark after running nightmare. I am in the process of getting this truck on the road, I haven't even driven it yet.
After the truck seems to be running just fine, SOMETIMES after you turn it off it will not start up. After it has sit it fires right back up. SO i figured brainbox. I put an msd box in it and pro billet dist. it still does the same thing. I did the msd spark test, and that worked. I have spark from coil wire, but not from the plug wires. almost everything is new, Battery,wires,coil,Battery cables, volt reg, ign switch, I added ground cable from motor to frame. I am about fed up with this thing, any Ideas on what could STILL be causing this? I am about out of ideas Thanks
Old Apr 3, 2013 | 09:31 PM
redroad's Avatar
redroad
Possibly cracked distributor cap even if it's new
Old Apr 4, 2013 | 12:05 AM
wilcam47's Avatar
wilcam47
also make sure the contact button on the inside center of the distributer is there...sometimes they "disappear/fall off" even on new ones...before you put it on the engine and this can cause problems
Old Apr 4, 2013 | 12:24 AM
vic_v8's Avatar
vic_v8
stupid question....is the starter engaging fully? because the rotor couldn't be turning without it...
Old Apr 4, 2013 | 12:37 AM
wilcam47's Avatar
wilcam47
cap and rotor?
Old Apr 4, 2013 | 01:39 AM
9d4's Avatar
9d4
had two different dist, total of three dif caps new rotor. Its something else. Im starting to think the truck doesnt like me
Old Apr 4, 2013 | 07:09 AM
kaimi01's Avatar
kaimi01
damnit I have the same problem!
Old Apr 4, 2013 | 07:20 AM
junkman 11's Avatar
junkman 11
Make sure the coil is hooked up propperly. Check resistance of the coil wire.
Old Apr 4, 2013 | 12:25 PM
wilcam47's Avatar
wilcam47
so do you have spark at the end of the coil wire ALL the time?? Then no spark to the wires??
Old Apr 4, 2013 | 12:27 PM
fmc400's Avatar
fmc400
MSEE
What is the state of the cap and rotor? How are you checking for spark both at the coil and at the plugs?
Old Apr 13, 2013 | 12:40 AM
wdfp's Avatar
wdfp
Did you ground the motor to the cab as suggested in the other post? That ones a pretty important ground. If the motor and cab is grounded to the frame it should be okay as long as they are good clean connections but I'd still run one to the firewall from the engine..
Old Apr 14, 2013 | 01:19 AM
9d4's Avatar
9d4
yes coil spark is always good, nothing coming out from dist, Im thinking maybe mag pickup. I did an ohm test to the pickup on the dist, and it was within msd specs, after it quit running I did another ohm test, would not register anything on the multimeter
Old Apr 14, 2013 | 01:20 AM
9d4's Avatar
9d4
What is a good part of the cab to use for a mounting point?
Old Apr 14, 2013 | 08:11 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
I have seen this once on a 351/400/460 MSD distributor. It was actually that the distributor had it's own ignition module in it and it didn't need a module hooked up, only the power/ground wires and a coil. We tried hooking it up with all kinds of stuff but never any spark to the plugs. It turned out that it was a distributor that needed just ground and like 12 volts or something to run. What is the distributor you are using? http://www.summitracing.com/parts/msd-8595
This one is one that requires no ignition module.
Old Apr 14, 2013 | 11:56 AM
MikePacey's Avatar
MikePacey
If your running the duraspark 2 I'd check the wiring connection on the distributor to the wiring harness. A couple years ago I had the same problem and it ended up being that the ground wire on the connection was coming out.
Also check the condition of the wires to your coil, could be getting hot or melted or possibly frayed. Now when you go to restart it does the truck turn over? Does it try to hit when your turning it over? Does it crank slow?
