I have a 1993 F-150 XLT. The first problem I need help on is that I can't lower the passenger window from the drivers side but I can put it up from the drivers side. Does anyone know how to repair this? Another thing is that the bench seat moves back and forth and doesn't seem to stay in place but the drivers side stays fine. If anyone could help me with advice on these it would be greatly appreciated
There is a wire, that goes from the drivers side lever, to the pass side to activate the latch. Mine came off, and the pass side was hung open allowing the pass side to roll free. Plus, spray the bejesus out of the moving parts while you have a look-see under there...
If anything, 4 bolts, a nice day and a beverage to remove seat for a better advantage and spring cleaning ta boot...
From the driver's side, the driver window is fully functional but the passenger window CAN NOT be lowered from the drivers side, only from the passenger side.
