Aftermarket Products
Sponsored by: Worksport
Drain plug for bedliner
Old Jun 4, 2003 | 07:35 AM
Bubba Shrimp's Avatar
Bubba Shrimp
Every time it rains I have a miniatrue swimming pool in the back of my truck. The bedliner doesn't have drain holes. Does someone make a kit that allows you to drill through the bedliner but seals the space between the bedliner and the truck bed so water doesn't get between the two?
Old Jun 7, 2003 | 11:10 PM
rebocardo's Avatar
rebocardo
Your truck does not have drain holes in the front of the bed, does it?
Are you planning on drilling a drain hole into the truck bed?
Old Jun 7, 2003 | 11:22 PM
Bubba Shrimp
I don't know if it has drain holes or not as I put the bed liner in just a few days after I bought the truck.
This can't be a new problem. I just wondered how other Ford owners delt with it, or do people not worry about it and let the water stand until you drive off in the truck and the water just runs out the back.
I thought I could get under the truck and look for any drain holes but it's rained the last two days and I haven't been able to crawl under there. LOL
Old Jun 8, 2003 | 07:58 AM
metalbender's Avatar
metalbender
I had TWO beds rust through because of slip in bed liners, I now use Spray in such as Rhino......never happened again
Old Jun 8, 2003 | 10:25 AM
Jim242002's Avatar
Jim242002
Mine drains out when I go down the driveway it all pours out...My bedliner has no drain holes in it....
Old Jun 8, 2003 | 11:54 PM
SouthernDually's Avatar
SouthernDually
Lightbulb Drain plug for bedliner
You just hit the nail on the head. The water and moisture retention is the main reason that I have gone to spray in liners in both of my trucks. My last truck was only 3 years old with a slide in liner and I found the entire bed rusted. Made me so mad, but it didn't do much good. I finally went to the spray. The best slide in liner made still has some flex and movement, this in turn causes scuffing on the paint and metel of the bed, hence RUST.
I did meet one fellow that took his liner out every week and cleaned and waxed his bed, way to much work for me. As far as a removable liner I think that the only one that I have heard of that doesn't rust is the BedRug. But I will admit that I havn't owned one personnaly. Good luck.
Patrick R.
General Automotive Discussion
Aug 15, 2016 07:33 AM
dustyroad
13
Oct 21, 2014 08:54 PM
Yahsu
Sep 27, 2014 04:49 PM
Jimmyrig
Aug 29, 2013 11:35 PM
CPT_Diesel
2004 - 2008 F150
Jun 5, 2012 01:49 PM
