300 Stroker question
Old Apr 2, 2013 | 10:53 PM
Orange84's Avatar
Orange84
I know the 300 is a stroked 240 and can never be bored so this must mean the head uses sleeves if I am correct. Now where can I buy sleeves or do I just have to have them machined up like we do for pulling tractors? I am really just wondering because I would like to get a 300 on a stand and start building it and would like to start with new sleeves pistons rings Ill keep the same rods but just trying to get an idea of where to get the parts if its even possible.
Old Apr 3, 2013 | 08:27 PM
Sw1tchfoot's Avatar
Sw1tchfoot
I'm pretty sure that the 300 does not use sleeves, you can have sleeves installed though. A quick google search says that you can usually bore a 300 Ford up to .060 over. Sleeves seem unnecessary, if the block is that bad you could get a used one for much less than any machine work would run you.
Old Apr 4, 2013 | 09:35 AM
Orange84's Avatar
Orange84
I read somewhere that the 300 was actually meant for a tractor and knowing alot of ford tractors and older model motors they all had sleeves so I just kind of assumed they had sleeves.
Old Apr 4, 2013 | 12:39 PM
dustybumpers's Avatar
dustybumpers
No sleeves.
It is also used as a statioary motor as well as industrial. I have never seen it used as a tractor motor
Nitesaber
Apr 29, 2011 05:07 PM
OKC_65_F100
Aug 8, 2010 03:56 PM
6inarowmakeitgo
Mar 29, 2010 12:01 PM
Dr. Dirt
29
Jun 16, 2008 05:47 PM
jwtaylor
Jun 7, 2001 01:08 AM
