D44 swap question
Old Apr 2, 2013 | 02:42 PM
Migs7's Avatar
Migs7
D44 swap question
Wondering what your thoughts are on actually running my truck with this D44 after fixin this crack? Im about to purchase this axle hoping it is a good deal since it has this flaw. I currently have 87 shortbed non 4x4.
Old Apr 2, 2013 | 03:14 PM
blue924.9's Avatar
blue924.9
well what do you use the truck for, off roading towing plowing, and how did you crack it in the first place. also i am fairly certain that a d44 is a ttb axle but i could bw wrong i guess
Old Apr 2, 2013 | 03:27 PM
Evan_P's Avatar
Evan_P
What part of the axle is that? It doesn't look too bad. Welding might fix it. If not you should be able to find another for pretty cheap.
And Blue, the Dana 44 came as a TTB in our gen trucks, but on 78-79 broncos they were solid axle. It is a common swap to rid all the issues of TTB, but is a lot of work to do.
Migs7's Avatar
Migs7
Corrected first post...
In actually collecting parts for an sas swap.
Old Apr 2, 2013 | 03:33 PM
Evan_P's Avatar
Evan_P
Seeing as it has already been welded once, I would try and find another one.
For your project, you have a lot of parts to get and a lot of work to do. SAS swap is difficult. 2WD to 4WD SAS is going to be even less fun.
Migs7's Avatar
Migs7
Its to the left of the pumpkin, her is an example of the location which is to the right of the pumpkin.
Old Apr 2, 2013 | 03:36 PM
Migs7's Avatar
Migs7
Gotcha thanks for the advice sir!
Old Apr 2, 2013 | 07:12 PM
GNR22's Avatar
GNR22
I don't think that doing an SAS with the old D44 is particularly hard. I've done 3 now. They are pretty tedious and time consuming though, and definitely not for a beginner. I've only done the swap with leaf sprung trucks though.
I wouldn't trust that axle. You'll end up sending a bigger crack through the housing going over bumps and stuff. I'd find another one.
Icuff4cash
Aerostar
Jun 1, 2016 09:17 PM
wm070779
May 25, 2009 09:54 PM
300-6
Offroad & 4x4
Jun 18, 2006 12:54 PM
jessecoit
Dec 16, 2003 03:16 PM
824x4ride
Sep 11, 2003 06:54 PM
