44 or 60?
Old Apr 2, 2013 | 11:42 AM
riverguideguy's Avatar
riverguideguy
44 or 60?
im trying to find out what axle i heve. i tried search but couldnt find exactly what i needed. the old owner said he thought it was a 60 but in my other thread a few guys said its a 44. well i was out this morning taking a wire brush to the pumpkin webbing and found a 60 stamped on it, the axle code on my door plate says 24p so what axle do i really have
Old Apr 2, 2013 | 11:51 AM
redroad's Avatar
redroad
First see if it's high pinion .. If it is then the axle code is irrelevant because it was swapped .. No highboy came with high pinion
If your not sure how to ID High pinion look at this pic see how the snout is in the upper half when you look at the whole pumpkin
High pinion Dana 60
High pinion Dana 44
Low pinion
Old Apr 2, 2013 | 11:56 AM
DirtGood's Avatar
DirtGood
If your axles are original it should be 60 front and rear according to fordification.com
Old Apr 2, 2013 | 12:00 PM
riverguideguy
the pinion is definitely low on the pumpkin
Old Apr 2, 2013 | 12:09 PM
redroad's Avatar
redroad
Does it have disk brakes and 8 wheel studs ?
Old Apr 2, 2013 | 12:14 PM
riverguideguy
yes it has both disk brakes and 8 lugs. i thought for sure it was a 44 until i found the 60 on the axle and now im just not sure what it is
Old Apr 2, 2013 | 12:26 PM
redroad's Avatar
redroad
It's more than likley a HD dana 44, 4:10 gears, and low pinion which were stock in highboys 76 to mid year 77 .. It still is a good front axle and will serve you well ..
Old Apr 2, 2013 | 01:16 PM
vic_v8's Avatar
vic_v8
I know your question is answered, but for future reference
Ford Dana 60 HP. Not a good pic, but it has king pins (cap with 4 bolts)
LP 44 from a 77 hi-boy. Notice the ball joints (one castle nut per)
Old Apr 2, 2013 | 01:47 PM
montana_highboy's Avatar
montana_highboy
i was out this morning taking a wire brush to the pumpkin webbing and found a 60 stamped on it.
Take the wire brush to it again, the "O" in 60 is actually a "C", under all the grease/grime it's often mistaken for a zero and guys think they have a 60 front.
Look at vic_v8's second pic and you can clearly (kinda) see the "44 6CF" stamp, indicating a 44HD axle.
Old Apr 2, 2013 | 02:00 PM
redroad's Avatar
redroad
with leaking power steering
Old Apr 2, 2013 | 02:05 PM
montana_highboy
You gotta love power assist, that's one well "lubed" front-end.
Old Apr 2, 2013 | 05:36 PM
vic_v8's Avatar
vic_v8
LOL, I have since pressure washed off the 30 years of ram pump.
Old Apr 2, 2013 | 05:40 PM
riverguideguy
i scraped it off to bare metal and your right it is a C duh! thanx guys
Old Apr 2, 2013 | 09:09 PM
montana_highboy
You're not the first guy to do that and you won't be the last.
51MHF5
Jul 7, 2013 02:39 PM
Stinky7-11
17
Nov 26, 2011 01:44 PM
windsor94
Aug 25, 2008 04:22 PM
Faithful Old Road Dog
Sep 1, 2003 05:34 PM
