lift question
Old Apr 2, 2013 | 08:57 PM
the5schlueters's Avatar
the5schlueters
so 33" tires will fit on stock truck with no mods? will they fit on the stock rims? Man this tire stuff is confusing.
Old Apr 3, 2013 | 12:42 AM
GNR22's Avatar
GNR22
33" tires that are narrow will fit with no modifications. Maybe narrow 35" tires will too. However, if you have wider tires (12.5" or so) you will have problems turning at full lock. The inside of the tires will rub the springs at full lock. To get around this, you get rims that are a higher offset so the tire sticks out more and gets away from the springs.
Old Apr 3, 2013 | 12:12 PM
the5schlueters
Ok i think its starting to make more sense to me. Did ford make any aluminum 8 bolt wheels? Kinda trying to stay as stock as possible but would like to find some other wheels other than the steel wheels. Or what wheels will fit it? Something I can find in the salvage yard.
Old Apr 3, 2013 | 05:01 PM
GNR22's Avatar
GNR22
I'm not sure if Ford did make aluminum wheels, I'm sure someone on this site knows for sure. Going to a scrapyard to look is probably smart. New aluminum wheels cost a pretty penny.
Old Apr 3, 2013 | 10:29 PM
jlr73322's Avatar
jlr73322
I own an F150 and recently purchased a tire and wheel package through National Tire and Wheel, ntwonline.com. They have pretty good prices on packages like that if you have to purchase both wheels and tires.
Old Apr 3, 2013 | 10:31 PM
jlr73322's Avatar
jlr73322
And, they also have a tire chart that will tell you if the truck will have to be lifted in order for the tires you purchase to fit. Look for the link on the website that states "Tire Fitment Guide". Hope this helps.
Wtfpwnt
2004 - 2008 F150
20
Jul 6, 2011 04:49 PM
dsands88
92
Dec 7, 2010 11:30 AM
Barndon
Dec 6, 2009 08:07 PM
Charbnovsky07XTR
2004 - 2008 F150
Aug 17, 2007 04:37 PM
13MWZ
Nov 14, 2002 06:44 AM
