302 engine in 92 step side
Old Apr 1, 2013 | 07:17 PM
sticky58's Avatar
sticky58
I`m putting an engine in my 92 stepside.I`ve noticed that the 95 engine that I`m using has the act switch in the air box instead on the intake.Rather than switching intakes,can I use the one in the air box without upsetting my computer.I would appriciate the answer if anyone has done this before? They are both roller engines with same firing order.thanks
Old Apr 1, 2013 | 09:59 PM
Conanski's Avatar
Conanski
You won't upset the computer but it won't ever go into closed loop with the airbox ACT sensor beause the computer is used to seeing closed loop ACT temperatures closer to engine operating temp.
Both roller yes but they don't have the same firing order. That won't affect this swap however as long as you don't try to use any wiring from the donor motor and route the plug wires for the 351/HO firing order on the replacement engine.
Old Apr 1, 2013 | 10:22 PM
sticky58's Avatar
sticky58
act sensor
so thats what I was afaid of,I`ll have to change intakes,I show the firing order as 1-5-4-2-6-3-7-8,looked it up in my mitchell on demand,thanks
Old Apr 2, 2013 | 11:39 AM
Conanski's Avatar
Conanski
That's the firing order for your '92, from '94 on it was changed to 1-3-7-2-6-5-4-8.
Old Apr 2, 2013 | 03:12 PM
sticky58's Avatar
sticky58
thanks very much, I appreciate the help and I`ll be sure and pass on the good deed...
jmikeyj4
Jun 9, 2010 09:06 PM
lucas1949
1978 - 1996 Big Bronco
Nov 1, 2009 07:34 PM
coquitlamford
Jul 16, 2004 10:37 AM
beuford79
General Automotive Discussion
Mar 18, 2004 04:09 PM
X-1
Feb 26, 2004 01:33 PM
