Multi purpose fog lights
Old Apr 1, 2013 | 04:13 PM
rescue947's Avatar
rescue947
I'm installing LED fog lights on my 99 ford ranger I'm wiring them to my headlights my question is can I run a wire to my turn signals as well so I can use them as turn signals also
I didn't know if I could splice a wire from my turn signals to the positive wire on the fog lights
Old Apr 1, 2013 | 06:01 PM
grandmas77f150's Avatar
grandmas77f150
Do you want them to blink even when the fogs aren't on with the headlights?
Old Apr 1, 2013 | 07:29 PM
rescue947's Avatar
rescue947
I want them to be on when my low beams are on and then turn off when I have my high beams on but I would also like them to turn on when I just have my marker lights on also
Old Apr 2, 2013 | 10:17 AM
pawpaw's Avatar
pawpaw
Better check with your State Laws, to make sure its ok to have the Fog Lamps also act as blinkers, as theyre not amber colored.
In any case you'd want to have the blink function controlled by a fused relay, so its making & breaking contacts are carrying/switching the fog lamp filiments electrical load.
Old Apr 2, 2013 | 10:23 AM
rescue947's Avatar
rescue947
So what wires do I need to connect to I have three wires and one is ground an one is marked minor and the other is major I believe is what there labeled. there's a video on you tube of guy who did what I want to do but I can't see which wires he hooked up
Old Apr 2, 2013 | 11:07 AM
pawpaw's Avatar
pawpaw
The LED fog light mfgr should be able to give you direction.
Old Apr 2, 2013 | 11:34 AM
rescue947's Avatar
rescue947
I have a question in my owners manual were it list my fuses and there location if the location says not used is the location still hot
Old Apr 2, 2013 | 11:39 AM
pawpaw's Avatar
pawpaw
Test it with your multimeter, or 12 volt test lamp & the engine running.
LiquidSteam
Aug 17, 2017 08:50 PM
cecilt
Mar 15, 2017 11:39 AM
berry1234
May 27, 2008 04:49 PM
98infinity
1997 - 2003 F150
May 11, 2007 11:35 AM
Bronco532
Mar 20, 2006 04:22 AM
