Fuel Mileage
Old Mar 31, 2013 | 04:34 PM
northy17's Avatar
northy17
Fuel Mileage
Hello, I have a 1989 F-250 lifted 6 sitting on 36s and i am looking into how i can get better mileage, The only engine mods i have done to improve the mileage is the cold air intake, does anyone have any suggestions? Thanks Nick
Old Mar 31, 2013 | 04:56 PM
Evan_P's Avatar
Evan_P
My advice, don't expect good mileage with 6 inches of lift and 36's. What engine and gearing do you have?
Old Mar 31, 2013 | 05:03 PM
northy17's Avatar
northy17
351w, I put in 65-70 dollars and get maybe 185 km out of it, and i don't know what the ratio is, it has a dana 60 on the rear end.
Old Mar 31, 2013 | 05:05 PM
blue924.9's Avatar
blue924.9
what do you classify as good mileage, with 6 in lift 36s and a 351 i wouldnt expect much
Old Mar 31, 2013 | 05:48 PM
cjben's Avatar
cjben
lose the lift and tires or get a 4 cylinder car if you want gas mileage. Not going to happen with your current situation.
Old Mar 31, 2013 | 07:12 PM
kegomatix's Avatar
kegomatix
I'm getting 11 city MPG stock height 33in tires with a 351, I'd hate to think what I might be getting with your setup.
Old Mar 31, 2013 | 07:58 PM
kermmydog's Avatar
kermmydog
I couldn't agree more. When I want gas mileage I drive our Honda Civic.
Maybe a higher lift, bigger tires, & a 460 will help.
Craig
Old Mar 31, 2013 | 08:13 PM
blue924.9's Avatar
blue924.9
Craig
what ya mean so he can power over a small 4 cylinder car hook the diff on er and have that cart him around
Old Mar 31, 2013 | 08:15 PM
BigBlockF350's Avatar
BigBlockF350
First of all, you're not exactly aiming for fuel economy if you're running 6" of lift and 36" tires... You're not going to get good fuel economy with that setup.
With that out of the way, I do understand the point of aiming for maximum efficiency with the setup that you have. Even if you can get only fuel mileage up 5%, it's still an improvement.
First, record your fuel mileage for a tank or two. You need to have a base point to know if any mods improve your mileage.
Try advancing your timing. That should help you a little bit. Many times, an aftermarket "cold air intake" doesn't really help you... It can actually make less power in many cases than a factory air box. Many times, a factory air box will give slightly more efficiency. Someone spent a lot of time designing it for that specific application.
Do maintenance things like fuel filter, spark plugs, plug wires, and distributor cap. Those should help it slightly, and it's good to replace those things if it's been a long time since they have been replaced.
A free flowing exhaust might help you out some too.
Old Mar 31, 2013 | 08:53 PM
GoinBoarding's Avatar
GoinBoarding
Your not going to see great mileage, ever, with that setup. But you can try to make it as efficient as it will be by (as stated) making sure its running top notch. Really do need to have a baseline mileage though. Fill it up, reset the trip, drive it as you usually would, fill it back up. Divide miles on the trip by gallons it takes to fill it back up. Or do kilometers/liter, the conversion is simple enough. Report back with a baseline and people will be able to give you pointers. If you're getting 6mpg on the highway, you have room to improve, but if you're already at 10-11mpg I don't think I would change a thing considering your setup. BTW you probably don't have a D60 rear axle unless it was swapped in (Sterling 10.25" fullfloat is more likely).
Oh and forget in town mileage, my F150 with 351 & stock (235/75R15) tires gets into the single digits pretty easily on short trips in town. On the open road, 70mph or under, 17mpg all day. Heavier truck, bigger tires, I bet 12 is the highest you could ever hope to get (probably really optimistic).
kermmydog's Avatar
kermmydog
Thumbs up
Great Idea. I love these type of threads. People need to get a grip or some common sense.
When I goggled Ford F150 351, 6" lift, huge tires, unknown gear ratio, a lot of things come up but good gas mileage wasn't one of them.
Craig
Old Mar 31, 2013 | 09:01 PM
blue924.9's Avatar
blue924.9
yeah it gets scary sometimes when i think real hard
Old Mar 31, 2013 | 09:06 PM
northy17's Avatar
northy17
I know I am not going to get great mileage with the setup i have to everyone telling me that lol, I am just looking around for some pointers on how to improve it, I have done my plugs, plug wire, distributor cap, fuel filter and other small stuff and still I am getting terrible mileage, I have been resetting my trip meter every tank and it is coming in right around 185 km every tank. And sorry I am not a mechanic that is why I am looking for help.
Old Mar 31, 2013 | 09:08 PM
DBGrif91's Avatar
DBGrif91
This thread should help with the cold air intake...
https://www.ford-trucks.com/forums/6...and-cheap.html
Old Mar 31, 2013 | 10:20 PM
BigBlockF350
\I have been resetting my trip meter every tank and it is coming in right around 185 km every tank.
What is is your "tank"? I'm assuming you have dual tanks. They're different sizes, so which one are you referring to? Also, you need to give us the numbers. Fill up your tank (top off until pump clicks off the first time), and record your odometer (or reset trip if you have that). Only drive on that tank. When it is getting close to empty, top it off again until the first click. Now, divide the distance driven by the fuel you put in. For example, 200km ÷ 45 liters = 4.44 km per liter.
For the folks following this thread who measure with the standard system (like me), 4.1 km per liter is around 10MPG. That was quick math in my head, so not 100% accurate but pretty close.
